Porsche 935's Avatar
EFI and Boost
How many guys out there run EFI and of those who do, how many of you run more than 1.2 or 18 psi boost? Like to see some of the heavy hitters rides.
Old 06-30-2014, 11:26 AM
Chain fence eating turbo
I plan on 2.0 bar once I get a MAP sensor that can take it (only on race gas and very limited use).
I have 1.4 bar springs and was running that with a Holset HX40, but now barely get over 1 bar with the new Borg Warner S366 due to the huge turbine.
Need to hook up the boost controller yet.
Old 06-30-2014, 11:45 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
2 bar with a fresh clutch and fresh rear tires. If they are too hard they just spin. It depends on what I'm doing and if the conditions can handle it.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 06-30-2014, 12:29 PM
xbmwguy's Avatar
Right now 1.4-1.5 will be going 2.0 very soon.ran my static pressure up to 53#s with e-85 pulling real hard. I think this gt4094 is just starting to breath at 20#s
Old 06-30-2014, 01:43 PM
Brando
quattrorunner's Avatar
Damn
Turbo powa!
1977 911s. it's cool
Old 06-30-2014, 02:27 PM
xbmwguy's Avatar
Tippy go with the "map daddy " it's a very stable 4 bar map sensor and is already recognized by ms3
Old 06-30-2014, 03:39 PM
Yep, that's the one I'll get. I have MS II.
Old 06-30-2014, 04:34 PM
I would rather be driving
jpnovak's Avatar
Fun. MS2 board surgery.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 06-30-2014, 06:16 PM
The directions seem harmless to solder in the MAPDaddy. Is it painful?
Old 06-30-2014, 06:19 PM
xbmwguy's Avatar
Jamie that will be a piece of cake for you
jpnovak's Avatar
Cory. It will take more effort to pull the MS2 board from the case than it will to solder in the new MAP sensor. I am happy to help if you want. you just need to enlist a tech at work to use the soldering station.
Old 06-30-2014, 06:46 PM
Yep! The MS components are huge compared to the ones we use. Should be easy for them.
Old 06-30-2014, 06:53 PM
Nice!!!!! Thought their were many more cars out there by now, but maybe not. Have only seen a couple youtube video's of some high boost turbos. One was running 30 lbs. boost and put down 830 hp to rear wheels. Look like a lot of 996 and 997's out there but fewer classic turbos. Don't care for new turbos, power is still impressive but no style.
Old 07-01-2014, 04:41 AM
911Velocity's Avatar
Air cooled rules. Spend $$$$, go fast, look cool. be good or don't get caught!
Gerry
84 911 Carrera (Supercharged), 67 427 Vette , 67 XK E-type Rdstr., 56 Vette
06 Cayenne Turbo S, 08 Vette Coupe, 57 Vette, 65 Chev Nova 327 4spd
65 Chev Nova 385 Race, 85 Chevy Rollback
97 Ford Exp. EB, 90, 91 Toy PU
Old 07-01-2014, 09:18 PM
totle's Avatar
When running as much boost as 1,5-2 bar, what is your timing at , and what CR?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 07-03-2014, 07:33 PM
Good question. GJF??
Old 07-03-2014, 07:37 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
I'm almost 8.5, I was shooting for 9:1 But with the addition of the big valves, it took a little away. (next set of pistons ) Twin plug allows you 8-10 degrees less timing, But with a flat top piston, it doesn't shroud the plugs, so there is not really a need, it just adds a little insurance. Anytime you can make the same power with less timing it's a plus. High flowing turbo compressor/s, Large, high flowing, high efficient Intercoolers are a must, to keep the charge temps in check. Its the IAT's that you really need to concentrate on, to make sure the chamber temps will not suffer. As far as timing at 65-6800 @ 2 bar I'm at 18 BTDC and 16 BTDC by 7200. (But every motor is different so some may like more or less) My IAT's are about 10-12 hotter than ambient on full boost.
Old 07-03-2014, 08:14 PM
What fuel?
Old 07-03-2014, 08:28 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
pump up to 1.4 over that some blend I mix.
Old 07-03-2014, 08:41 PM
totle's Avatar
GJF, what hp are you making at 1 bar and 1,4 at pump gas?
Also what hp at 2 with mixed fuel?
Trond R.
1986 944 Turbo
Old 07-03-2014, 11:07 PM
