Ingenieur
Stock 0.8 bar wastegate - annular spacers inside
I took apart my Porsche wastegate to measure the valve to guide clearance, and I found 2 spacers inside. Is this the stock arrangement? Do you leave them in when you put in a 1 bar spring?
Not stock. The spacers you have are usually added to increase boost. You should have a thin steel washer above and below the spring.
Ingenieur
Thanks for your help. I figured they were aftermarket. I did/do have the thin steel shims. For those who have not seen it before, here are pictures of Porsche wastegate guts. I measured my valve guide clearance at around 0.3mm.
WASTEGATE BODY & LATER STYLE MUFFLER (note bronze guide) ![]() INTERIOR OF EXHAUST GAS PASSAGE ![]() TOP SIDE & VALVE GUIDE ![]() INVERTED STYLE WASTEGATE VALVE ![]() WASTEGATE VALVE SEAT (This plate fits with a light press to the main body) ![]() CANISTER BOTTOM (note port for boost pressure) ![]() The canister top, diaphragm, and valve retainer are shown above. |
Metal Guru
So what pressure was your wastegate opening up at with those spacers? Are you getting any blow by through the valve guide?
My stock w/g was shot at 70k miles. I replaced it with a Tial and never looked back.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Ingenieur
The boost pressure was around 0.8 bar with spacers. That is puzzling, isn't it? I wonder if the spring took a set with that much preload (each spacer was 10mm thick). The rest of it seems to be in good shape, no evidence of blowby. I wonder if they are born with a pretty big valve guide clearance.
Metal Guru
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb Last edited by 911nut; 07-06-2014 at 01:17 PM.. |
Ingenieur
Fiber gasket tore apart during dis-assembly. I used some graphite gasket material to make a new one. I don't know how well that will work. It can take the temperature, but it seems pretty soft. If it doesn't hold up I will try grafoil. Mr. Gasket sells that as part number 5960.
mine was leaking too.
i put enough pressure in to open it. i could hear and feel the air coming out of the exhaust pipe. put a tial on there.
