jfort's Avatar
heat control box/flap
hot air blows into cabin uncontrollably. heater control lever opens and closed heat control boxes, at least it appears to from the outside, and the springs seem OK. I suspect that the flap inside the box has failed. I have two new ones coming from our host.
I will start applying penetrating oil on nuts this evening and letting it sit for a couple of days until parts arrive.
any other suggestions or advice?
Jeff Fort, Findlay, Ohio
70 914-6 2.7
07 Carrera C2S
05 Cayenne V6
Old 07-07-2014, 11:08 AM
jfort's Avatar
for follow-up and possible edification: the heat control boxes appear to be operating correctly. with a little lubrication, the flap in the box pivots as it should. i think the control wire connecter may have slipped on the left box thus allowing hot air through even though the control lever in the cockpit was closed. I pulled a little more of the wire through and tightened it. bent it after the nut so it won't slip again. took it for a spin on I-75 and it seems to work correctly.
70 914-6 2.7
07 Carrera C2S
05 Cayenne V6
Old 07-08-2014, 07:00 AM
Tinkering Pays!!
mooney265's Avatar
good deal [especially in the Summer]! mine did something similar when I first purchased the car... Easy fix!! Wish they were all that easy
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 07-08-2014, 07:30 AM
16Volt's Avatar
Sweet fix, I was kind of looking forward to see the replacement as my driverside box is cooked. The shop forced it closed for summer thankfully.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 07-08-2014, 07:47 AM
