Slfan's Avatar
Turbo does not engage
Hello,
My friend had engine and fuel system (CIS) work done on his stock 1982 930. After this service, the Turbo is not engaging at all. Does anybody have any idea what can be causing this problme or where should they start to look at? Any guidance would greatly be appreciated.
Thanks,
Slfan
1979 911 SC
1983 930 "Special Wishes" Factory Slantnose
1988 M3 (E30) - stock!
Old 07-11-2014, 07:35 PM
Wastegate issue?
Cheers,
Patrick
'78 930 #441
'87 951
Old 07-11-2014, 08:10 PM
89 930.
Benny771's Avatar
Check for tears in the wastegate diaphragm. Fairly easy job. Does the boost come on at all?
Old 07-11-2014, 09:14 PM
Crotchety Old Bastard
RarlyL8's Avatar
Does the engine sound and drive normally but simply not achieve boost?
When the engine is at boost rpm and the throttle is punched what happens exactly?
Old 07-12-2014, 11:06 AM
Slfan's Avatar
Pputkowski, Benny771 and RarlyL8,
Thank you pitching in with your input. It is greatly appreciated. I will share this with my friend and ask him to describe me what exactly occurs and if any different sounds are generated when he steps on the accelerator and the turbo does not engage. Will be posting this info soon.
Regards,
Slfan
1979 911 SC
Old 07-12-2014, 02:29 PM
7.0:1 > 11.3:1
Intercooler not seated on O-rings? Perhaps the mechanic overlooked one of the bolts which hold it down.
Old 07-12-2014, 03:26 PM
beepbeep's Avatar
If wastegate diaphragm is ruptured engine will overboost, not loose the boost.
I would start with checking intercooler O-rings and recirculating valve (which might be stuck in open position)...
Thank you for your time,
Old 07-13-2014, 01:08 PM
Slfan's Avatar
Jim2 and Beepbeep,
Thank you for the guidance. Will look into these possibilities.
Regards to all,
Angelo
1979 911 SC
Old 07-13-2014, 01:29 PM
Smart quod bastardus
fredmeister's Avatar
Second this. Recirculating valve being hung up internally would cause this. Make sure the hoses going to the recirculating valve end caps are connected. You should be able to hear the piston inside the housing slamming back and forth when blipping the throttle hard from idle. Mine makes a slapping sound occasionally when I do this.
fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 07-14-2014, 12:03 PM
