LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Hi..i am a new user here. You will be offering a dwur & software controlled by a ms ecu. This replaces the stock/blwur, and retain the cis system. Will you be offering a package with the above items and whatever basic sensors needed to get this going? Then, the only thing needed is the ms? What type of laptop is needed to run the software?I'm in the middle of a 3.0 rebuild and still looking at some options. Either rebuilding the fuel head/wur and most likely replacing the injectors, or a basic efi. Since I have the cis stuff I'm leaning towards using it.
printed circuit board assembly service
Old 09-05-2016, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #601 (permalink)
Originally Posted by Reanimotion View Post
It's simple but not obvious at first glance.
The table axis values need to be changed to suit
On the bottom left corner of each table is a button with a 90 degree bent double arrow on it
Press that and the X & Y axis values for load and RPM or whatever can be edited
Ah, You need a registered version. I had registered, but hadn't entered the code yet.
doh!
Old 09-05-2016, 08:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #602 (permalink)
After Start Enrichment and Warm Up Enrichment.
There are some default tables in Tuner Studio for these. However, that is one of the functions of the Control Pressure Regulator aka Warm Up Regulator (WUR). In fact, this is the function we model with that base map (see above).
Should these After Start Enrichment and Warm Up Enrichment tables be disabled or zeroed out somehow? Left alone? Would we be better off using these functions to control warm up mixture and make our Base Pressure Map a flat line?
Old 09-05-2016, 10:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #603 (permalink)
hight's Avatar
design overview is at Frankencis and triggering Bosch CDI
as far as I'm aware no-one has tried it yet, as most have gone for either MSD or individual coil control.
Everything is wired up, an working. Exept the rpm signal, got both wires (opto+) connected to the coil, but no signal. i'am using a 123tune ignition, no standard one.
is that a problem?
greetings Mike
1984 VW Golf mk1 GTI Pirelli Schrick turbo k-jet
2000 Seat Ibiza 6k2 1.6 8v
Old 09-05-2016, 01:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #604 (permalink)
umop apisdn
Hi, contact mike at Dkubus - sales@dkubus.com
He will be happy to help provide what you need
The stock WUR performs both of these functions, so I initially zeroed out the tables
After start and taper all zero
Warm up all 100
once you get it running then flattening the base control pressure curve and introducing the Warm up and After start adjustments is definitely an option
Because of the electric heater in the stock WUR it actually is closer to the After Start table in operation - stock it begins at the pressure assigned to the current temperature but goes to full lean within arounnd two minutes because of the internal heater.
is that a problem?
Opto+ to coil+ and Opto- to coil- ? Unless 123tune are doing something weird to control the coil it should work if the system is using a standard 12v coil
It might be best to move the opto+ input to the tacho signal if you can and opto- to ground
the coil connection is designed for 12v points ignition so may not be liking the electronic distributor
1981 928S 4.7 ROW with KE3-Jetronic and Franken8 (AEM Inifinty) follow at [http://www.frankencis.com/Activity-Feed/userid/2]
Yes! mechanical/hydraulic constant flow injection can be managed by a modern EMS
www.FrankenCIS.com
Old 09-05-2016, 04:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #605 (permalink)
ok so I think I've settled on my plan of attack for this. First, I plan on dynoing the car to get a base HP and torque number as is.
Then I'm going to put the Fcis in with just the sensors, no control, no eWUR. So I can log RPM, MAP, IAT, WBO2 and drive that around for a while. My plan during this phase is to pick up MAP from a T in the line from the TB to the stock WUR. This is non-ported MAP and s/b stable enough for this application.
For the IAT I plan on drilling and tapping the BOV housing between the I/C and the TB and putting the IAT sensor in the airflow there.
I'll also record as best I can the system and control pressures with my gauges but without some re-plumbing of the fuel system I won't be able to collect that with the FrankenCIS or while driving around.
Once I've got some basic information I can use as a starting point I will install the eWUR block and connect the Inj2 to the lambda valve and give the FrankenCIS full authority. I'll continue to get MAP from the same place. I'll tune this as best I can and then dyno again just to see if there are any improvements to be gained on a mostly stock engine with FrankenCIS.
Then I'll install the RarlyL8 headers, hooligan, K27, TK intercooler (with integral IAT port), re-tune, and dyno again.
I'm building a detailed step-by-step on this and will start posting in a separate thread soon.
Old 09-09-2016, 06:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #606 (permalink)
I'm building a detailed step-by-step on this and will start posting in a separate thread soon.[/QUOTE]
Excellent. I believe your the first to install this system on a 930 so, thx for blazing the trail and documenting it.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 09-09-2016, 08:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #607 (permalink)
hight's Avatar
No, the manual says opto+ grey/red wire to coil- and opto- to the coils +
what are you meaning by; opto+ to tacho signal?
greetings, Mike
Old 09-25-2016, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #608 (permalink)
umop apisdn
The manual is correct for direct coil connection, but assumes a points based ignition.
sorry for the incorrect assumption on +/- in the post as I've never used that configuration
I had Opto+ connected to the tachometer output of the Porsche CDI ignition controller and Opto- simply grounded
If your tachometer is fed from the 123 ignition box and not the coil then tapping in there may give results
www.FrankenCIS.com
Old 09-25-2016, 08:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #609 (permalink)
hight's Avatar
my 123ignition is not a box.
https://www.123ignitionshop.com/gb/tune-volkswagen/109-123tune4rvv.html
looks like this one
Old 09-25-2016, 09:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #610 (permalink)
umop apisdn
OK, there appears to be just the four wires and no dedicated tachometer output.
The recommended Opto wiring for the MicroSquirt and MegaSquirt relies on Flyback voltage from the coil when it fires and the magnetic field collapses
The 123tune, being electronic, may have internal diode protection from that pulse and therefore the MicroSquirt can no longer see any reverse voltage to trigger from
Does your car have a tachometer and if so where is it getting it's signal from?
www.FrankenCIS.com
Old 09-25-2016, 04:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #611 (permalink)
hight's Avatar
Yes, gets its signal from ..... the coil
Old 09-27-2016, 10:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #612 (permalink)
Are the changes you guys made to the firmware available as a diff or a separate file that can be compiled in when the firmware changes for the MS?
Or are we stuck on what will eventually become and orphaned firmware version if we go MS?
Old 09-27-2016, 03:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #613 (permalink)
umop apisdn
from the wiring diagrams I found here it looks like the tachometer feed is a red/black wire? if the tachometer is connected to coil-, then I would try connecting opto+ there and Opto- to ground
make sure the MicroSquirt is set to "Basic Trigger"
www.FrankenCIS.com
Old 09-27-2016, 05:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #614 (permalink)
umop apisdn
at present, no diff, although we have been including relevant changes and bug fixes as they come out.
The primary FrankenCIS control code is out in it's own sub module and there are a few key bits that are in the main MSExtra code to allow it all to work.
Apart from the new CAN stuff we are pretty much in line with MSextra 3.4 and will keep it updated.
www.FrankenCIS.com
Old 09-27-2016, 06:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #615 (permalink)
hight's Avatar
did it, no rpm signal, think microsquirt is failing. Bring him to check and repair if needed.
Old 10-02-2016, 02:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #616 (permalink)
umop apisdn
If you feel like experimenting a bit and think the unit may be faulty anyway try:
disconnect both of the OPTO connections
connect VRIN+ to the Coil- ( Tachometer )
leave VRIN- disconnected
so simply one wire only from the microsquirt to the coil
OPTO and VR1 share the same processor input but are separate and very different external input designs
The VR inputs on the MicroSquirt v3 use a MAX9926 self adjusting signal conditioner which can handle several hundred volts from a VR sensor as well as 0-5v and 0-12v signals from hall sensors or even points. By leaving the VRIN- disconnected or floating it tells the conditioner to look for changes above and below 2.5v
Above 2.5v = On, Below 2.5v = Off
discussed here Megasquirt Support Forum (MSEXTRA) • New dual VR board V2.0 (View topic)
www.FrankenCIS.com
Old 10-02-2016, 07:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #617 (permalink)
hight's Avatar
microsquirt is failing. They are going to fix him. hope to get him back soon.
Old 10-06-2016, 10:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #618 (permalink)
hight's Avatar
Had microsquirt back today. Connect it, and it worked, for a minute. Now failing again.
Opto+ to coil-.
Opto - to ground
did the vr1 option, signal is working, but not stable and not the right rpm's.
Old 10-08-2016, 06:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #619 (permalink)
umop apisdn
Try VRIN+ on the Coil-
VRIN- should not be connected to anything
www.FrankenCIS.com
Old 10-08-2016, 07:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #620 (permalink)
