Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
hight's Avatar
Originally Posted by Reanimotion View Post
Try VRIN+ on the Coil-
VRIN- should not be connected to anything
Did it see my post before yours.
Old 10-08-2016, 07:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #621 (permalink)
umop apisdn
I missed the edit
Whatever the 123tune distributor is doing must be creating or allowing voltage spikes on the coil
If VRIN+ is working but inaccurate, try turning on "Noise Filtering" in the Ignition Settings menu
1981 928S 4.7 ROW with KE3-Jetronic and Franken8 (AEM Inifinty) follow at [http://www.frankencis.com/Activity-Feed/userid/2]
Yes! mechanical/hydraulic constant flow injection can be managed by a modern EMS
www.FrankenCIS.com
Old 10-08-2016, 05:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #622 (permalink)
umop apisdn
For those that intend to interface FrankenCIS with a Frequency Valve controlled Lambda fuel head there is a firmware update 5.5.6k available at www.frankencis.com FrankenCIS_firmware_release_556k.zip
This resolves an issue found by 'awjens' where the FV output was reversed or inverted
www.FrankenCIS.com
Old 10-10-2016, 11:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #623 (permalink)
hight's Avatar
Yess, its working again! got my rpm signal!
1984 VW Golf mk1 GTI Pirelli Schrick turbo k-jet
2000 Seat Ibiza 6k2 1.6 8v
Old 10-18-2016, 08:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #624 (permalink)
3 restos WIP = psycho
kenikh's Avatar
This is good news.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-18-2016, 11:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #625 (permalink)
umop apisdn
Cool !!
what did you end up using to get it to work, VR and noise filter or OPTO ?
www.FrankenCIS.com
Old 10-18-2016, 06:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #626 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
umop apisdn
Table 2 values are now correctly oriented and the allowed range is 0-200 where 100=50%
If you would like the table to be 0-100 and reflect actual percentage just change the “Freq valve Duty to VE%” setting on the Injector Dead-Time page to 2.0 instead of the normal defat setting of 1.0
If you are running the latest version 3 of Tuner Studio it has an internal firmware update tool now
Very simple to use and walks us through the process nicely
Tools Menu - > Update/Install Firmware
www.FrankenCIS.com
Old 10-20-2016, 03:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #627 (permalink)
Can you explain this in a little more detail for the slower members of the audience, like me.
Old 10-21-2016, 09:51 AM
  Pelican Parts Technical Article Directory    Reply With Quote #628 (permalink)
umop apisdn
Sorry, a bit of geek-speak shorthand in that
Basically the frequency valve has a range of Zero to 100% and normal operation is at 50%
with lower being lean and higher being rich
With our standard table setup we have a value of 100 in the cells as normal
so 101 to 200 tunes a richer mixture
and below 100 leans it out
This is with "Freq valve Duty to VE%" set to 1.0 or a 1:1 ratio as we are actually controlling the valve in half percent steps
If we change the setting to 2.0 it then means the table values are directly proportional to the Frequency Valve values
so Zero is off , 100 is fully open and 50 = 50% or half way
this is now in 1% steps so we lose a bit of resolution, but someone may prefer this option
The recommendation is to have it at 1.0 so Table 1 which controls the WUR and Table 2 which controls the Frequency valve are both operating the same with 100 as the centre or normal fuel delivery.
www.FrankenCIS.com
Old 10-21-2016, 05:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #629 (permalink)
I've been going through the settings and trying to make sure everything is set for an initial start. K-jet w/lambda. I'd appreciate it if the more knowledgeable could have a gander at these and advise if incorrect or insane
AFR 1 and 2 are identical as are VE 1 and 2
Old 10-23-2016, 11:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #630 (permalink)
umop apisdn
Seems ok
make sure you have the latest firmware installed (5.5.6k)
www.FrankenCIS.com
Old 10-23-2016, 02:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #631 (permalink)
umop apisdn
a little off topic
would there be any interest in a drop in engine position sensor for the Bosch VR distributors?
www.FrankenCIS.com
Old 10-23-2016, 05:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #632 (permalink)
Yes D.O.P
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 10-23-2016, 06:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #633 (permalink)
A good position !
Yes Sir !
Old 10-23-2016, 09:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #634 (permalink)
umop apisdn
The optical CAS I'm using in the above prototype is a Nissan SR20DET unit
the adaptor plate is 3D printed ABS at the moment but will be Acetal or Aluminium
The sensor has been modified by cutting off the plug and bending the pins up to fit inside the distributor housing
This is a 928 distributor so will need to confirm dimensions for a 911 unit before committing
The Nissan unit has 180 effective crank teeth and four cam (360+4 pattern) and that high a resolution needs a good ECU to read it (AEM infinity does!)
there are lower resolution wheels available though
the Bosch shaft is thicker than the usual 10mm Nissan/Mitsubishi/GM setups so a laser cut disc is probably going to be necessary
I'm looking to see if I can use a DSM or GM Optispark sensor instead of the Nissan unit so the hacking of the plug can be avoided
www.FrankenCIS.com
Old 10-23-2016, 10:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #635 (permalink)
umop apisdn
The internal diameter of the 928 Distributor is 83.5mm
if the 911 is smaller I doubt we can make it
www.FrankenCIS.com
Old 10-24-2016, 12:32 AM
  Pelican Parts Technical Article Directory    Reply With Quote #636 (permalink)
umop apisdn
rough measurements from photos indicate an ID of around 75mm
www.FrankenCIS.com
Old 10-24-2016, 04:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #637 (permalink)
hight's Avatar
Cool !!
got it repaired, so now working on opto. but now it looks like the injector isnt working. gotta fix that.
Old 11-03-2016, 11:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #638 (permalink)
umop apisdn
Sorry you are having trouble with the Microsquirt, they are normally very tough little boxes.
I've done some terrible things to mine over the years and it's happily kept on ticking.
www.FrankenCIS.com
Old 11-03-2016, 03:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #639 (permalink)
FrankenCIS does not fit on an 86 930 and probably other similar models.
I found that the damper fouls against the mounting boss of the throttle body.
Has anyone else discovered this or found a solution?
Old 11-19-2016, 01:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #640 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
