LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
umop apisdn
The frequency valve morphed into CIS-E with the DPR and the control mechanism is basically the same and is therefore worth investigating. If the range is sufficient it could be the key to full control without having to swap fuel systems it also might be possible with some creative plumbing to convert to CIS-E levels of control via the FV. Because there are basically three generations of CIS and GEN1 we know cannot do Gen2/3 control methods there are still a number of options for all intended levels of silliness.
I think the issue to date has been one of tradition - the WUR was the thing we tuned so the add on solutions played within the same area. Until we get some fuel running through these things we won't know which of the combinations is the best option.
1981 928S 4.7 ROW with KE3-Jetronic and Franken8 (AEM Inifinty) "Be the man your dog thinks you are."
Yes! mechanical/hydraulic constant flow injection can be managed by a modern EMS
www.FrankenCIS.com
Old 08-07-2014, 05:03 AM
Forced Induction Junkie
WERK I's Avatar
Thanks Steve. I look forward to your continued success.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 08-07-2014, 06:10 AM
umop apisdn
Originally Posted by WERK I View Post
IMHO, if you want max response times of CIS, everything should be sensored in real-time upstream. Throttle Position and Air Mass will insure fuel mixtures stay at optimal levels.
Upstream sensing is definitely the primary strategy, I'm considering the expansion points as variables in pressure manipulation rather than their effect on the CP sensing
www.FrankenCIS.com
Metal Guru
911nut's Avatar
Back in the late 1980's and early 90's, the U.S. DOT/EPA were only concerned with emissions at low engine speeds, i.e. stop and go traffic, so Porsche spent only so much money on a system they knew they had to replace in the near future.
If we (Porsche 930 owner's), have to convert fuel systems from Bosch type to another Bosch type, it may not be to our advantage in the long run. It may be time to bite-the-bullet and go EFI.
IMO, the more accurate term to use here is "constant engine speed" as that was the only time that the Lambda logic box could control afr by manipulating chamber pressures.
My feeling is that Steve's solution will have it's place among those who wish to keep as much of the stock system in place for originality reasons. Those who desire max performance will convert to EFI anyway.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 08-07-2014, 06:44 AM
umop apisdn
It's pure stubborn lunacy that started this adventure so don't forget the loony demographic as potential adopters.
www.FrankenCIS.com
Old 08-07-2014, 08:19 AM
DSPTurtle's Avatar
I guess I have completely missed the point of your project. The UTICS digiWUR simply dealt with control pressures. It sounds like you are trying to figure out how to blow more gas in the intake or something. Sorry for my intrusion.
I still think there would be a heckuva a market to replace just old WURs. It's not rocket science but there isn't a big enough market for the big engineering firms to solve this.
I don't know about you guys, but my BLWUR still needs to be played with every few months. It's a great workaround but its not a "solution."
Old 08-07-2014, 11:03 AM
Brando
quattrorunner's Avatar
Whats new?
Turbo powa!
1977 911s. it's cool
Old 08-14-2014, 10:53 AM
umop apisdn
I'm interstate this week for a wedding, will be back on deck next week.
I'm told the 6 prototype metering blocks are being completed now, and we have the rest of the goodies needed on hand.
The body side of the wiring harness in the vehicle is complete and the MicroSquirt tested with the new firmware and harness. Wideband O2 / MAP / Coolant / RPM and vehicle speed are all functional.
I've set it up initially for a replaceable engine side harness as we go through the possible install combinations.
Nearly there folks, the next few weeks should be interesting
www.FrankenCIS.com
Old 08-14-2014, 06:46 PM
torresmd's Avatar
subscribed!
1986 930 Slant nose Black/black RUF
2004 996TT Gaurds red/Black EVO GT 660
2001 Ferrari 360 Spyder Rosso/Tan
1969 Carrera Widebody TurboKraft Custom (Mexico Blue)
2001 E39 M5 Imola/Black-red interior
Old 08-14-2014, 07:10 PM
umop apisdn
I returned from interstate today and the prototype blocks were waiting on my desk
www.FrankenCIS.com
Old 08-19-2014, 03:08 AM
Turbofrog
smurfbus's Avatar
Sound interesting and good luck with the results.
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 08-19-2014, 03:50 AM
sithot's Avatar
CNC or "manual"? I hope it's the former.
Old 08-19-2014, 05:25 AM
umop apisdn
CNC
two machines - lathe and mill
www.FrankenCIS.com
Old 08-19-2014, 05:55 AM
sithot's Avatar
The ONLY way to make them affordably unless you are paying for the machines!
Haas CNC Vertical Machining Center (VMC) | Haas Automation®, Inc. | CNC Machine Tools
Old 08-19-2014, 06:16 AM
WERK I's Avatar
Steve,
Very Pu-u-u-u-rdy!
Are those sensors or fittings circled in the pic?
Dave
Old 08-19-2014, 06:30 AM
umop apisdn
Thanks, the guys normally do medical and scientific work so are used to fine work. As these are only prototypes they have been left raw, normally they would be tumbled and anodised as well.
The items circled in the pic are 0-100 psi digital pressure sensors
www.FrankenCIS.com
Old 08-19-2014, 06:38 AM
umop apisdn
First validation run during install and sensor calibration
more to come tomorrow
www.FrankenCIS.com
Old 08-23-2014, 01:24 AM
umop apisdn
This is all with the standard WUR in place and CP monitoring
upper
RPM
AFR Target
AFR actual
Lower
MAP
Control pressure
expanded to 10x for detail
and
Logging on road tomorrow for base line and then installation of the eWUR to see what we have
www.FrankenCIS.com
Old 08-23-2014, 08:31 AM
Cool stuff! Looking forward to hearing more and it looks like something good is coming.
Old 08-23-2014, 08:51 AM
Brando
Let's call this EFC cis for electronic fuel control
Or ECP cis for electronic control pressure.
Old 08-23-2014, 09:05 AM
