LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Were do you guys take the tacho signal in engine bay?
Old 01-31-2018, 02:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1001 (permalink)
puddy's Avatar
Originally Posted by kenikh View Post
Funny enough, I'm replacing a Tec3 with mine and plan on using the Electromotive coils as well. They can be used with an inline igniter - the Tecs have igniters on the motherboard, and the MS does not. Very common. Lots of shrink wrapped solutions for this issue on diyautotune.com.
Sent from my Nexus 6P using Tapatalk
Is this what you mean by an inline igniter?
https://www.diyautotune.com/shop/coils-ignition-systems/ignition-coil-amplifiersignitors/
Does it make more sense to buy this or just buy a better ECU that has it built in?
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 01-31-2018, 05:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1002 (permalink)
I wrongly installed the 2 firmware files selecting "connect anyway" instead of "Update ECU Definition".
Could be a problem?
What should I do to repair the installation?
Old 01-31-2018, 12:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1003 (permalink)
3 restos WIP = psycho
kenikh's Avatar
This: https://www.diyautotune.com/product/bosch-bip373-coil-driver-mod-kit/
Unsure of there's an MS2 implementation with on board coil drivers.
Instructions:
https://www.diyautotune.com/support/tech/other/bosch-bip373-ignition/
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-31-2018, 12:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1004 (permalink)
umop apisdn
Could be a problem?
You can manually select the correct INI file from within the project settings
open your project
if you get the following screen again select "Update ECU Definition" and select the correct INI file
otherwise
go to file >> Projects >> project properties
in the middle of the page there should be a tick box "Other / Browse"
Tick the box and a find file window will open
Point to the correct ini file which was included with the firmware s19 file
1981 928S 4.7 ROW with KE3-Jetronic
"Be the man your dog thinks you are."
www.FrankenCIS.com
Old 01-31-2018, 02:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1005 (permalink)
You should be able to run 6 smart 4-wire COPs or go CNP in a wasted spark config on the same microsquirt as is controlling your fuel without additional igniters.
I was thinking about twin plug and COPs haven't gotten far enough to see if I need anything special to drive essentially 4 COPs off each ignition event.
Old 01-31-2018, 02:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1006 (permalink)
Splice into the tacho wire from the CDI, black/purple I think
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1007 (permalink)
Thank you Steve for your support.
Now a little updating:
Microsquirt connected and in working conditions, registered version of Tunerstudio with Frankencis firmware installed,
a 36-1 trigger in front of crank pulley, an AEM wideband x series, here I read a value of 0.2 more on the pc compared to the gauge.
Now I'm connecting the device, how thick should be the wires?
Where to connect the ground? To engine or I've to use the Microsquirt one?
Could I use the original 4 poles Cts?
I don't have TPS ,Wich one could I adapt?
What is the minimum required to start the engine ?
The car is a Mercedes C124 3 liter 6 cylinders ke III.
Old 02-04-2018, 10:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1008 (permalink)
umop apisdn
Mike from Dkubus is the best to ask about Mercedes installations
If the AEM wideband is calibrated correctly on the Microsquirt, and the wiring is good, I'd personally trust the PC over the gauge.
By 'Device' if you men the DPR/EHA module then the DPR module should have 20ga or better wiring, max is 150mA with the norm around 30-40, so not much current capacity needed. Grounding with the microsquirt is best.
TPS is not really needed, the MAP sensor is sufficient for both load and acceleration data.
www.FrankenCIS.com
Old 02-04-2018, 11:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1009 (permalink)
On the Frankencis wiring diagram I can only see tacho out.
What pin should i use for this tacho in?
Old 02-05-2018, 12:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1010 (permalink)
umop apisdn
from Post #940
Pick up the RPM input by splicing in to the Black/Violet signal line from the CDI to the tach and connecting that to VR1+, leave VR1- floating.
www.FrankenCIS.com
Old 02-05-2018, 02:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1011 (permalink)
Hello,
I've completed all the connections: Dpr, Map,trigger wheel.
Today I tried to configure tunerstudio.
The first part "Engine and Sequential Settings" is ok, but on "Injector dead time/PWM" I can change values only on " battery voltage correction", the others parameters aren't activated.
Old 02-09-2018, 07:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1012 (permalink)
umop apisdn
go back to engine and sequential settings
what have you selected for Injector Port Type?
it should not be "Port Injection / T-Body" as that selects normal EFI mode
www.FrankenCIS.com
Old 02-09-2018, 03:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1013 (permalink)
What do you recomend?
Should i buy tunerstudio ms Ultra with logg HD
Or just tunerstudio ms and the logg?
Old 02-09-2018, 03:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1014 (permalink)
umop apisdn
I own and use both the standard MS version along with Log HD
Ultra seems to include Log HD plus some extras in the one package for very close to the same price of MS/HD so I would go for Ultra
tunerstudio-feature-matrix
www.FrankenCIS.com
Old 02-09-2018, 03:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1015 (permalink)
umop apisdn
Ultra should not need the separate Log HD
www.FrankenCIS.com
Old 02-09-2018, 03:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1016 (permalink)
Thank you Steve,
Yes, I've selected ke jetronic/dpr.
I've also reinstalled your firmware.
What should I try now?
Old 02-09-2018, 07:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1017 (permalink)
umop apisdn
For KE-Jetronic / DPR mode, there is nothing to be set on the Injector Dead-time page in version 556kU
Battery voltage correction should be the only active field
The K-Jetronic base settings section is for earlier WUR based systems only
www.FrankenCIS.com
Old 02-09-2018, 08:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1018 (permalink)
The K-Jetronic base settings section is for earlier WUR based isystems only
I'm little confused because on section 3.2 CIS-E page 16 of Frankencis manual there is the injection dead window where I see Dpr Max - duty cycle enabled.
Old 02-10-2018, 01:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1019 (permalink)
umop apisdn
manual was done using screens from 5.44
changes to CIS-E code in later versions now have VE to mA in an approximate 1:1 ratio with battery voltage compensation so the manual settings are not necessary
www.FrankenCIS.com
Old 02-10-2018, 05:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1020 (permalink)
