LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Originally Posted by Reanimotion View Post
check the active values are correct for your engine
does your coolant (engine temp) value get above 71.1C, if not, lower the active above to something smaller
Today set EGO control authority to 0 and the problem has disappeared.
Temperature is around 90 C, I don't have TPS, Micro read 6% as fix value so here no problem.
I read somewhere about same problem with Megatune caused by corrupted INI file.
Maybe I've the same issue?
Old 09-29-2018, 12:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1081 (permalink)
umop apisdn
Originally Posted by 9dreizig View Post
Steve looking at my two heads the AL is obviously the 86 but the second pic is my 79.. Could I just not add a Lamda FV ?? Am I missing something ?
the extra small port near the main inlet is missing on the iron head
, that is the lambda channel for the main chamber.
1981 928S 4.7 ROW with KE3-Jetronic and Franken8 (AEM Inifinty) follow at [http://www.frankencis.com/Activity-Feed/userid/2]
Yes! mechanical/hydraulic constant flow injection can be managed by a modern EMS
www.FrankenCIS.com
Old 09-29-2018, 04:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1082 (permalink)
umop apisdn
an Authority of 0 should lock it to 100%, basically the Auth +/-% tells the system how far it is allowed to adjust
FYI in addition to the settings for RPM,TPS,MAP and coolant the internal code also checks for TPS and MAP Accel/Decel and if active will also turn off the correction
www.FrankenCIS.com
Old 09-29-2018, 04:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1083 (permalink)
Disinstalled and reinstalled tunerstudio, EGO controls is there.
Maybe to much fluctuations.
Old 09-30-2018, 02:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1084 (permalink)
umop apisdn
in your logs, compare "AFR" and "AFR target", they should be pretty close to each other for normal operation of the EGO Correction.
VE needs to be set to get AFR as close to the target as possible before EGO is turned on
Then you have the ability to tune the EGO response by adjusting the PID section and Authority value
Authority sets the overall min/max limits of any allowable change
PID sets how fast and how far those changes are between calculation steps, and either creeps up on the desired value or quickly attacks and overswings then corrects again oscillating around the target.
It might also be worth looking at softening the MAPdot response to make sure accel/decel is not being triggered by small MAP changes, as there seems to be a lot of wiggle in the MAPdot line you have there. EGO Correction is small where MAPdot is large so it might be turning off at thos points.
The advantage of FrankenCIS is we have the full range of MegaSquirt capabilities to play with, the flip side of that is there are lot of interactions between those features and half of the complexity in tuning is getting everything balanced in the system so it behaves well by responding both quickly and correctly.
www.FrankenCIS.com
Old 09-30-2018, 04:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1085 (permalink)
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Hey Steve
I'm still chasing my CIS system and want to be sure I have a good Frequency Valve but can'f find a new one.. Here's what I have for a Bosch # is this correct ? 0280150300
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-16-2018, 03:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1086 (permalink)
umop apisdn
0280150300 seems to be correct for the Porsche
there are different part #'s depending on the hose configuration (e.g. 306 for Mercedes, 322 for VW etc.) so I would double check your existing one before ordering anything
www.FrankenCIS.com
Old 10-16-2018, 04:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1087 (permalink)
9dreizig's Avatar
That's the problem I can't find the correct p/n for the 86 930
Old 10-16-2018, 05:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1088 (permalink)
Is it stamped on the part do you think?
If so, my engine is out I'll have a butchers and see if there's a number on it.
Old 10-18-2018, 03:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1089 (permalink)
umop apisdn
the Bosch number will be visible on the plastic top/side of the injector body (inlet & connector area)
www.FrankenCIS.com
Old 10-18-2018, 04:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1090 (permalink)
Finally got around to checking this today while searching the shop for my scavenge pump which I can't find grrrrrrrr....
Anyway it looks like 0 280 150 300
Old 11-03-2018, 07:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1091 (permalink)
I found this when searching that part number. These might be a useful reference for someone attempting something like FrankenCIS on a modified car with higher fueling requirements, or re-adding a lambda valve to a head originally made without one.
Old 11-19-2018, 03:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1092 (permalink)
umop apisdn
0 280 150 300 is
242 cc/min @ 4.7 bar
dead time 2.5 ms
and
low impedance @ 2.4 ohms
www.FrankenCIS.com
Old 11-19-2018, 03:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1093 (permalink)
My engine is in the reassembly phase now, just buttoning up the chain housings and valve covers. Had the flywheel machined to 60-2. Excited to see how FrankenCIS will work with SC cams, an eWUR block, ignition, and EBC
Old 11-19-2018, 03:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1094 (permalink)
9dreizig's Avatar
Me too!!!
"Todd"
Old 11-19-2018, 04:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1095 (permalink)
umop apisdn
me three
although mine has been in that phase for nearly a year now
Admittedly I'm being overly ambitious with the eThrottle and CNP ignition, but hey, crazy is as crazy does
www.FrankenCIS.com
Old 11-19-2018, 04:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1096 (permalink)
me three
I bought Denso COPs but not using a TPS, just going to use speed density
Old 11-20-2018, 08:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1097 (permalink)
fasteddie313's Avatar
Getting anxious for spring to play with this stuff some more again..
80 931S LSD-G31 Big Breaks FMIC
1 Bar so far
Old 01-02-2019, 08:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1098 (permalink)
umop apisdn
I feel your pain I miss my 928 as well
I just spent the last week freezing my butt off in NYC and Quebec
I don't think I could survive over there with cars being a seasonal thing
Sub-tropical is awesome! I've only got to navigate work and travel commitments.
www.FrankenCIS.com
Old 01-02-2019, 09:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1099 (permalink)
I've been busting my ass working on the 930. I was hoping to get done over the new year break but one delay after another. Getting close though!
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition, and EBC. SC cams, K-27/29, Tial 0.8bar, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 01-02-2019, 10:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1100 (permalink)
