LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Originally Posted by Reanimotion View Post
A pressure sensor in the control pressure feed is definitely a must have - even just for logging purposes.
I'm testing a small and inexpensive digital 0-100 (7 bar) unit that seems to be available on eBay for around USD24.
A T-fitting in the line or a 1/8npt drilled and tapped into the side of one of the aftermarket injector holders for those with the bypass injector setup. The little block and banjo fitting above would be nice too.
Forgive me for not reading through the thread again !!! Just wondering how this worked.. I"ve got my MS and a few other items and just want to be sure I have all the items I'm going to need.
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 01-22-2019, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1101 (permalink)
umop apisdn
If you are using Lambda/FV control only then the pressure sensor is not needed by the system. it's only used for the eWUR control.
However, logging system and/or control pressure is still certainly useful and can be done by adding the pressure sensor to the existing lines with something like the below
Originally Posted by Hot Euro View Post
Len made this fitting for me last year:
On my later KE-3 fuel head there is a 8mm test port on the lower chamber and I've also removed the cold start circuit so am using the upper central port to monitor system pressure. Both ports are M8x1 so I machined the 1/8 NPT sensor thread down to M8x1 to fit the sensors without an adapter.
The alloy Lambda head I have here has a test port on the top system pressure gallery that feeds the cold start injector but nothing dedicated on the lower chamber.
1981 928S 4.7 ROW with KE3-Jetronic and Franken8 (AEM Inifinty) "Be the man your dog thinks you are."
Yes! mechanical/hydraulic constant flow injection can be managed by a modern EMS
www.FrankenCIS.com
Old 01-22-2019, 05:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1102 (permalink)
Old car guy.....
Hot Euro's Avatar
Looks familiar, had Len (BoxterGT) build mine then added a gauge.
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 01-23-2019, 04:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1103 (permalink)
Hi everybody!
Hi Steve!
Could You please explain to me this?
The DPR value in mA I see on tunerstudio gauge is what ecu asks to pressure regulator or it's the real value of the current? I hope the question is clear.
I noticed a few days ago empty spaces when I accelerate rapidly from idle, done some datalogging and I see negative peacks in dpr values, even -60 mA.
Normally I should have an increase.
Old 02-09-2019, 03:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1104 (permalink)
umop apisdn
the DPR Ma shown in the gauge is the total mA value the system is commanding (request)
if you are seeing negative spikes there is something in the control values dropping the commanded fuel amount or causing the fuel cut to trigger
overspeed or overboost maybe?
how stable is your RPM signal, are you getting spikes on the RPM input during acceleration
www.FrankenCIS.com
Old 02-09-2019, 08:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1105 (permalink)
Since this thread is still rocking here's few snaps of my FCIS modified rear electrical panel about ready to go back in.
As the last picture shows, I extended the "shelf" portion of the rear panel to accommodate new goodies while still leaving space for the rear wiper relay, rear window heater relay etc. I have run additional power to the panel and will be delivering it to the dedicated fuse block via a relay mounted on the square adapter in the LHS corner or the panel. Now, mounted on the rear panel I have:
-Microsquirt
-6 position ATC fuse block
-Relay adapter 911 round hole to standard modern square adapter, my own design I may start selling once I've road tested the design
-2x3Bar pressure sensors for MAP and constant baro adjustment, on a 3D printed bracket of my own design
-Boost control solenoid
-3D printed terminal strip for connectivity with ignition and sensors
Not shown is the knock sensor controller, still remains to be mounted.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition, and EBC. SC cams, K-27/29, Tial 0.8bar, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 02-10-2019, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1106 (permalink)
^^^ Nicely done.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 02-10-2019, 09:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1107 (permalink)
umop apisdn
Beautifully done, with extra points for no zip ties
www.FrankenCIS.com
Old 02-10-2019, 04:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1108 (permalink)
lol thanks! admittedly my lacing skills aren't what they were, but it looks ok and is solid.
Old 02-11-2019, 08:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1109 (permalink)
