LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
umop apisdn
The current tested system diagram is below
WUR replaced by our metering block and injector
#5 (hot start valve) replaced by our pressure sensor
#15 may or may not be needed depending on installation
1981 928S 4.7 ROW with KE3-Jetronic and Franken8 (AEM Inifinty) "Be the man your dog thinks you are."
Yes! mechanical/hydraulic constant flow injection can be managed by a modern EMS
www.FrankenCIS.com
Old 09-22-2014, 08:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
Just add lightness...
prebordao's Avatar
Originally Posted by Reanimotion View Post
If you post a photo on your blog, I'll send you one of the prototypes
PM me
Done.
pjr
74' Lime Green 911S Targa
nineelevenophilia.wordpress.com
Old 09-23-2014, 12:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
umop apisdn
OK,
I'm going to put in a small run of production blocks, does anyone have any comments on the current configuration, especially regarding lines to and from the FrankenCIS block and the current free location of pressure sensor.
My thoughts were that every install would be different so keeping it all modular means the DIY/mix-n-match option is still possible.
In a week or so I'll have a sneak preview of our 'Pro' version of the project for anyone that is interested in a more advanced setup, and as a consequence there will also be a FrankenSqwirt ECU very soon! so watch this space.
www.FrankenCIS.com
Old 09-23-2014, 05:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
prebordao's Avatar
Steve i'm assuming the thread sizes for those lines are the same as for a bosch wur, right ?
Old 09-24-2014, 12:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
umop apisdn
Correct - M10x1 inlet and M8x1 outlet
www.FrankenCIS.com
Old 09-24-2014, 12:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
umop apisdn
Much longer drive today (without logging) on a reasonably warm day in the mid 20s metric .
Ran very nicely from cold to hot in traffic, I'm very pleased with the outcome so far.
Prototype block does have an issue with the 1/8 NPT plug that blocks the end of the outlet chamber, as it warmed it appeared to wash out the permatex #3 sealer and weep a bit, so I removed and replaced with Teflon tape until I can get hold of the production units. If you have a prototype, I'm officially recommending for safety reasons to use it as a paperweight or re-tap the end for a metric washer seal. Do not install in a vehicle as is!
www.FrankenCIS.com
Old 09-25-2014, 07:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
umop apisdn
Ok Gents,
We've collectively gone through the phase one prototype stage.
We've shown we can do it. Now we need to discuss how we want to do it for particular models before we progress.
1 simple block as per prototype with remote mounted pressure sensor somewhere else in the CP line, with or without Bosch damper as appropriate.
2 more complicated and less flexible all in one attempt containing injector sensor and damper in the one block.
Looking at your existing WUR and the CP plumbing
a. are there any clearance issues regarding height, width or length that should be catered for? e.g. limited or no space to the left of the WUR due to proximity of throttle body on xx 911
Len from Autosport Engineering is on board for proper metric fittings and lines for anyone who needs factory level plumbing
For anyone wanting to go AN lines I have access to a small quantity of M8-Dash3 M-M stainless fittings if required
I'm also putting together a Wiki on one of our servers for documentation and will publish as we go through the second stage verification
www.FrankenCIS.com
Old 09-26-2014, 09:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
Brando
quattrorunner's Avatar
If in modular form, I would want all part numbers for an application to be on one site linked in a parts diagram for my application so it's easy to know what I'd need. Or else just kit form for each application. Looks like this could be for many cis cars o I understand the level of crazy it must be to imagine a kit for every car. You'd have to quit your day job.
Turbo powa!
1977 911s. it's cool
Old 09-26-2014, 09:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #168 (permalink)
prebordao's Avatar
I would go for
1- a completely modular form selling it as "specialized" parts: block, fittings, ecu
2 - an assembled simple kit containing everything for the most common / simple application: sensors, injector, block, fittings, fuel lines, ecu
pjr
Old 09-26-2014, 01:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #169 (permalink)
umop apisdn
Unit #2 (Adelaide, Australia) installed and running on the dyno today with no damper.
Will post results as soon as we have them to hand
Unit #3 in Portugal will have a basic and unique DIY control system
And - just because we don't have enough to do it looks very much like we might have an OEM level control system soon, as an economical long term alternative to the MegaSquirt solution.
www.FrankenCIS.com
Old 10-02-2014, 11:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #170 (permalink)
umop apisdn
FrankenCIS apparently works on more than one vehicle
Mercedes SL500 V8 K-Jetronic
Quote from the dyno tune test - "...we could make the AFR what ever we wanted! Awesome."
The vehicle was reportedly very rich down low and lean up top, so with the FrankenCIS set to 0.01bar resolution, adjustment ranges of -10kpa and +20kpa across the appropriate areas of the map brought everything together.
www.FrankenCIS.com
Old 10-03-2014, 03:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #171 (permalink)
dos531's Avatar
When is the 930 test going to happen?
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
'01 996tt
Ducati 748R
Old 10-03-2014, 10:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #172 (permalink)
umop apisdn
As soon as we can find someone silly enough to volunteer.
Alan in NZ is the closest I think, and only a shortish international flight away.
www.FrankenCIS.com
Old 10-03-2014, 04:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #173 (permalink)
Forced Induction Junkie
WERK I's Avatar
Darn! Missed it by that much!
I'm putting the car away in about 2 weeks, I'd be a bad Beta tester with that little time.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 10-03-2014, 04:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #174 (permalink)
GAJ GAJ is offline
1992 - 964 Turbo volunteer
If you need another tester please let me know, I'm a systems engineer and maybe can contribute at least as testing mule. Please PM prices with s&h to Miami, Florida, 33166.
1992 C2 Turbo in Rubystone Red
Old 10-06-2014, 11:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #175 (permalink)
umop apisdn
pm sent
www.FrankenCIS.com
Old 10-06-2014, 04:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #176 (permalink)
umop apisdn
Ok we have a few options for the metering block coming
1 a production version of the simple prototype
2 an all in one including provision for the Damper and Sensor
3 we are toying with the idea of a two piece modular block to hold a narrow body standard length or pico injector
Thoughts?
The ECU side Open Source project can be found on our website shortly - in the mean time Open5xxxECU.org • View forum - Reanimotion's Skwerts
We are rebooting the Open5xxxECU concept initially for us and CIS but eventually an ecosystem for all and sundry, hobby or commercial along the lines of Arduino or Linux.
www.FrankenCIS.com
Old 10-07-2014, 05:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #177 (permalink)
dos531's Avatar
Are you going to sell these as a set or just the metering block and we source all the other bits and pieces?
'01 996tt
Ducati 748R
Old 10-07-2014, 08:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #178 (permalink)
umop apisdn
Just the block for the moment and the NanoSkwert when available
For MicroSquirt and the rest of the components there is no sensible way we could compete on a small scale with local suppliers and the Bosch network.
If it looks like FrankenCIS will become a viable commercial venture for us then we would definitely look at creating a basic kit including the specialised sensors and ECU.
We also want to foster the Open Source community aspect of this by having alternative suppliers and implementations. For example the Mercedes tuner Stuttgart Classics / Dkubus will be packaging their own implementation using a our block and ECU but doing their own sensors, harness and plumbing to suit the supercharger kits.
www.FrankenCIS.com
Old 10-07-2014, 08:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #179 (permalink)
prebordao's Avatar
If I understand correctly, option 3 will open up a lot more possibilities regarding injectors / flow rates. On the other hand, for this particular purpose, the available range of side feed injectors is probably enough and the appropriate blocks (1 and 2) are neater / simpler and probably cheaper.
Between option 1 and 2, I think it will come to the particular installation. I will start myself with option 1, as I'm trying for the minimum possible setup. I'll even start by using the existing oil temp sensor instead of a dedicated one.
Steve, regarding option 2, wasnt'it advisable for damping reasons to locate the damper closer to the FD ?
pjr
Old 10-09-2014, 02:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #180 (permalink)
