klefroid's Avatar
pig pig pig rich (video)
car is going pig rich!
no fuel related mods, bone stock
Slightly bigger turbo
964 cams
Headers
How is this possible with a stock model 78 euro car?
Some people are trying to get more fuel but I'm trying to get less!
Car is holding at 4000 rpm.
Little bit black smoke (hard to see)
Ignition is set right.
I made another vid but quality is not so good.
Sounds is bad (more like a train ) as my windows and roof where open.
P pig rich - YouTube
Old 07-14-2014, 12:54 PM
If your car has two fuel pumps and two fuel pump relays the rear fuel pump relay also powers the heater elements on the WUR/CPR and the cold start aux air valve.
If the rear fuel pump relay stopped working the car will usually still run on the front pump only but then the heater elemenrt on the bimetallic spring thermostat in the WUR cools off and it lowers the control pressure which richens the AFR.
Just one of many possiblities with CIS... and it happened to mine while driving once.
Old 07-14-2014, 01:25 PM
klefroid's Avatar
I think your spot on, well almost!
The rear fuel pump is starting to make a strange and loud noise.
Should I replace both or would the noizy one be enough? If one fails most likely the other one follows or am I wrong?
I need to buy a cis pressure tester! it's all about money money money
Here's the sound, what do you guy's think?!
Pump sound - YouTube
Old 07-14-2014, 01:53 PM
I'm referring to the rear fuel pump relay in the front trunk, not the actual rear fuel pump. If the rear pump is making noise it's getting some electricity and the relay is probably ok.
Check the electrical plug on the WUR and see if it's getting 12 volts when the rear pump is running. If it isn't getting electricity it's going to stay in cold start mode.
There's many things that can and will eventually go wrong with CIS. This is just one thing that can cause the problem you described.
Old 07-14-2014, 02:14 PM
klefroid's Avatar
I know you did. I went to the car when you told me about the fuel relay. and while testing one by one I noticed that the rear feul pump is way to loud so I need to replace the fuel pump. not sure if you can hear it in the vid but it's not making pressure. When I turn on the front pump you hear in the first second it's building up pressure. So that's why I'm pig rich. I checked the wur and it's getting 12 volts!
All credits to you Sir! Thanks
Little question. Why would you choose a 044 fuel pump above a stock one?
Old 07-14-2014, 02:42 PM
[QUOTE=Little question. Why would you choose a 044 fuel pump above a stock one?
[/QUOTE]
They cost way less if you buy them on ebay or amazon and get a real one doing it
They can flow more fuel too.
Old 07-14-2014, 02:56 PM
klefroid's Avatar
Great! Let's get one now
Old 07-14-2014, 03:09 PM
[QUOTE=klefroid;8163796] and while testing one by one I noticed that the rear feul pump is way to loud.
It's not always a sign of a bad rear pump when it is loud; it may be a sign of a bad front pump. When a front pump starts acting up, the rear pump gets louder and louder. Simple test on two good pumps: pull the front pump relay and listen to the good rear pump roar.
Old 07-14-2014, 06:19 PM
Chain fence eating turbo
Ooh, poor cylinders and oil getting washed out. Hope you get her sorted soon.
Old 07-14-2014, 06:48 PM
klefroid's Avatar
That problem came just after the new turbo. After 3 gaspump stops it's worse then before. May be an easy fix.
Old 07-14-2014, 09:50 PM
klefroid's Avatar
I found one loose wire on that normaly connects to the starter.
So there are two small wires, one to activate the starter and the other one is for ???
I looked true threads and did not found good info. If the wire is not connected to the starter, what happens then?
Old 07-19-2014, 03:23 PM
Robbbyg's Avatar
Sounds like the pump is working but its sucking Air ?
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 07-19-2014, 05:01 PM
klefroid's Avatar
I got two new pumps but need an adapter to install them. if there was a leak then there would be fuel leaking, no?
Old 07-19-2014, 05:06 PM
