-   -   Determining if I have original tires 1983 Turbo (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/820760-determining-if-i-have-original-tires-1983-turbo.html)
texis300 07-15-2014 03:13 AM
When I picked up my car I was told that it had original tires and wheels. After some settling in I am trying to decipher if this is true. I have pics of the tires. Does anyone know what the OE tires were on the 1983 911 Turbo cars?
This will further determine what I am going to do with the car.
http://forums.pelicanparts.com/uploa...1405422598.jpg
http://forums.pelicanparts.com/uploa...1405422662.jpg
http://forums.pelicanparts.com/uploa...1405422825.jpg
speednme1 07-15-2014 05:21 AM
Original or not, those need to go to the recycling bin.
onboost 07-15-2014 06:08 AM
^^^ what he said.. time to Trash'em
Those would not be original to that car I don't think.. since they're DOT and the car is Euro? I want to say that tire is early 90's?
TZ 197 07-15-2014 06:13 AM
OE tires
My first 930 a 1979 had original tires still they were Pirelli P-7's
Jeff NJ 07-15-2014 06:49 AM
According to the date codes, the top tire was manufactured in the 2nd week of 2002 and the bottom tire was manufactured in the 8th week of 2001.
Not sure what tire age has to do with deciding what to do with the car. Nobody wants original tires on an old car.
The wheels should have codes on them too. They are stamped on the inside of the center of the wheel. I am sure if you post pics of the codes, people can tell you when they were made, and while it can't prove that they came with the car, it can tell you whether they were made for that model year or not.
texis300 07-15-2014 07:31 AM
Original tires would go to the merit of this being an unmolested, fully original car.
I know that the tires are trash, I would not drive on them for any amount of money.
I am trying to do some research on the car that I have and figure out what it came with originally to the way it currently sits. With the ODO showing 20419 miles, no sunroof, 4 speed, turbo, cloth car..... I am trying to piece it all together.
It will be for sale I just need to make sure I have all of my ducks lined up first.
texis300 07-15-2014 07:32 AM
I will pull the wheels and take pics of the inner faces and wheel hoops as well.
unclebilly 07-15-2014 08:28 AM
So now that it is obvious that the tires have been replaced, at least once (look at the wear on the lug nuts), this means the car was driven hard (burnt the tires right off her in 10,000 miles) and put away wet (look at the rust on the undercarriage and rotors.
texis300 07-15-2014 08:52 AM
Yes it sat outside for 9 years.......
It is by no means a cream puff, but in the same token, it is not beaten up either.
Rust on the rotors is a fact of life I can show you a car that has sat outside for a month and it will have rust on the rotors as well.......
There is a TON of tread left on the tires, not that it matters......
reachme 07-15-2014 12:25 PM
If that were Zuffenhausen air from the month of manufacture in those tires you should capture it like freon. and no im not serious
texis300 07-15-2014 03:51 PM
It would be bottled gold from the Mother land, No?
(I am not serious either)
speednme1 07-15-2014 05:54 PM
9 years? though it may not have been beaten by a human it has been b***h slap by mother nature...:D The wheel(in the pic) looks like it needs refurbishment, suspension items will need to be replaced as well...not just shocks and struts either(bushings too). You have your work cut out for you my friend...
krasuskyp 07-15-2014 06:03 PM
seems to appear to be overspray on the oil lines and spring plate cover in the wheel well pic - any hopes of originality in that regard are probably moot
who cares about the tires or paint - it's a cool car being non-sunroof / cloth...
...tho... 20k mi...
um, yeah... that one would require docs to believe which charted the miles over time, registration / emissions confirmations, etc.
These odo's are tooooo easy to unplug / swap, and all too commonly have their gears turn to dust, sooooooooooo...
again, regardless - great find, and good luck to you whichever direction you opt to go w/ it
JJ 911SC 07-16-2014 01:17 AM
Conversion time... https://www.google.ca/search?client=safari&rls=en&q=tire+flower+pots&ie= UTF-8&oe=UTF-8&gfe_rd=cr&ei=ZELGU5XdEMrB8geru4HYBg#q=tire+flowe r+pots&rls=en
http://forums.pelicanparts.com/uploa...1405502182.jpg
texis300 07-16-2014 02:40 AM
The car was last registered in 1992-93.......so I am going to be inclined to believe the mileage/ Not to mention the fact that the car is unmolested. The overspray as you are pointing out (or what appears to be overspray) could have been from the federalization of the car.....Regardless. Yes the car will need a complete resto top to bottom for concours events. This would be a very good driver with a little work.
zaman fu 07-18-2014 09:09 PM
So replacing old, worn tires is "molesting" your car? I learn something new every day. If I saw a car with tires like that, my concern would be that it was neglected.
Robbbyg 07-19-2014 02:23 AM
I think from 1977 they were all 16x8 rear, 16x7 front, ?
IS it a Matching Numbers car have you checked?
Tt surgeon 07-19-2014 09:22 AM
I think '77 cars were 15" rims, no?
This car is a nice potential project for somebody, if the price is right.
C
texis300 07-19-2014 11:58 AM
It is number matching.
Original tires would bolster the mileage claim.
zaman fu 07-19-2014 04:43 PM
Given the condition of what's in the picture and how common odometer fraud seems to be with Porsches of a certain vintage (i.e. those that are not so old that no one gives a **** about mileage anymore), the mileage claim seems dubious.
Hams930T 07-19-2014 10:41 PM
Oddly enough one picture of a tire seems to show a date code in 1981. I am not certain of this - but it sure looks no different than date coding embossed on tires today.
IMO - numbers matching chassis/motor/trans will bolster value. With that said - mileage will certainly be nearly impossible to verify unless you can track the mileage of the car when it was federalized and then track mileage thereafter. 20K would be cool - it's just sad the condition of the car as it will really affect value.
Good luck; I remember seeing your pictures from another thread you posted. I cringe at the cash investment it will take to bring this car back.
Chris.
