1986911's Avatar
How much fuel pressure is too much?
I have spent the last few months tinkering with my Leask WUR. I finally have it where I want it (or close enough). Its on an 89 930.
13.5 idle
14.7 cruise
11.6 full boost .9 bar
I had the car tuned on a dyno a while back and the shop shimmed the plunger on the fuel head to correct a lean full boost condition. A while later, I installed a WEVO AFR monitor. I realized the settings from the shop had changed. Lock tight was not applied to the "onset of boost" allen head bolts and they fell out. I was getting 10.3 upon the onset of boost.
I have to say the Leask Wur's are awesome.
I have read here that the spec for an aluminum fuel head should be around 100 psi. I don't know exactly how much I have but it blows past 100 PSI on my CIS gauges. My max reading is 100 so I am thinking 120 or 130 psi.
Should I leave it as since its running well, or remove the shims to put the fuel pressure back in spec and start over again with the AFR's?
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 07-19-2014, 05:41 PM
