jfort's Avatar
Engine Oil Temperature
Even on a relative cool day, my 77 930's oil temperature will be just below the 250 mark. Seems high to me. If I get on it a few time so that the turbo kicks in it gets even higher. Normal?
Jeff Fort, Findlay, Ohio
70 914-6 2.7
07 Carrera C2S
05 Cayenne V6
Old 07-23-2014, 12:20 PM
No, check your thermostat.
Old 07-23-2014, 12:51 PM
Nope, as you suspect... however, it's not always"that bad". Additional cooling helps, but you really need to find out the source of overheating. It could be as simple as AFR or timing or an oil cooler fan, complicated as valves, rings, internal wear... You should not see those temps unless idling for long (traffic) or at the track; and it should go down as soon as you bring the engine speed to its sweet spot.
Old 07-23-2014, 01:00 PM
Brando
quattrorunner's Avatar
First check your cooler lines going up to the cooler in the fender, they're probably hot but if not the thermostat is a problem. Next check to see what cooler is up there and if it has a fan, get one if you have a carrera cooler with no fan. but as stated above, it can get confusing after those have been checked.
I'd say you have lots of reading ahead of you. I do think that's too hot.
Turbo powa!
1977 911s. it's cool
Old 07-23-2014, 01:12 PM
Kartoffelkopf
Spenny_b's Avatar
My 2p....I'd get another temp sender to start with, rule out the noddy possibilities first.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 07-23-2014, 01:42 PM
jfort's Avatar
thanks for the info, guys. Looking at a radiator-type fender cooler to replace the trombone. But I'll check the thermostat this evening first.
70 914-6 2.7
07 Carrera C2S
05 Cayenne V6
Old 07-28-2014, 02:15 PM
jfort's Avatar
the oil lines to the right front fender get hot so I don't think it's the thermostat. today it was in the seventies and the oil temp was normal. by the way, it has the original trombone cooler. i think i will buy and install a radiator-type cooler from elephant.
70 914-6 2.7
07 Carrera C2S
05 Cayenne V6
Old 07-29-2014, 06:51 AM
If the trombone oil cooler lines are hot ,yes that thermostat would be flowing, but what about the thermostat for the oil cooler on the engine? a temperature gun would help identify if that was is working. Then move on to improving the front cooler.
Old 07-29-2014, 04:59 PM
