LinkBack | Thread Tools | Rate Thread |
Broken head stud symptoms.
I've gone native
Yes, a broken stud could lose compression.......among other things.
'07 997.1tt Blk/blk 600hp, bad to the bone |
Really?
3 restos WIP = psycho
Finding head nuts in the valve covers when doing a valve adjustment is the sure fire symptom. Take a magnet and pull on every head nut when you have the valve covers off. If any are loose... Broken head stud.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Similar sound under accel as bad exhaust gasket.
John 79 930 |
Have the studs ever been changed? If not, way likely. They all brake eventually.
Millage???
Rick Dougal rkdougal@gmail.com |
Registerd 930 user nut
My broken head stud sounded like Pop Pop Pop through the exhaust system. not like a back fire just a pop when under boost. Cant miss it. Normaly there is no noise except the regular exhaust note. If you hear a pop under boost you have a broken head stud or two.
Thread Tools | |
Rate This Thread | |
