-   -   Intake porting vs not porting (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/824332-intake-porting-vs-not-porting.html)
gumba 08-07-2014 11:34 AM
Does anyone have a dyno number showing the h.p./torque difference between stock intake 32mm vs 36mm? Where the ONLY change was enlarging the intake ports, injector blocks, and the cis manifold.
One school of thought I'm hearing is since the turbo is pushing air by increasing the port size the air is moving at a slower speed (his words not mine). It's all so confusing.
This is on a mildly modded 3.3, sc cams, k27, headers, stock cis & ignition. The dyno number doesn't need to be specific to a 3.3, but more to a slightly modded motor.
mark houghton 08-07-2014 11:57 AM
Of course, increasing the port size would reduce the velocity or speed of the air (put a nozzle on a garden hose, see the velocity increase as a result).
But isn't the real benefit of larger ports, the delivery of more air volume even though it may be flowing slower? Just my thoughts, I'm not a wizzard on this topic. There must be hp and/or torque benefits, or people wouldn't be doing it. Would indeed be interesting to see dyno numbers.
tailwind22 08-07-2014 12:38 PM
My guess is Chris Carroll of Turbo Kraft would be well versed in these specific numbers.
911nut 08-07-2014 01:17 PM
Increasing port size is a tradeoff. Theoretically, low engine speed performance will suffer due to low port velocity and inefficient fuel atomization but more mass is delivered at high engine speeds, increasing power. I say theoretically because every time I drive a early big port 911 SC, for instance, it seems to has better low end power than my old small port SC did.
I've never driven a big port 930 but Chris Carroll told me that the 3.3 really responds to big ports (Carrera size ports: 41 mm),
gumba 08-07-2014 02:25 PM
His opinion was based on a turbo pushing air, vs a n/a motor pulling air. Big ports on a n/a motor pull more air/fuel in, where a turbo pushing would deliver fuel faster through a smaller opening.
RarlyL8 08-07-2014 02:36 PM
Velocity is more important in the turbocharged exhaust while volume is important in the turbocharged intake. This is not dissimilar to how bigger turbos make more power than smaller turbos at the same boost level.
9Thirty 08-07-2014 05:07 PM
More air is always good.
gumba 08-07-2014 05:58 PM
Still no proof?
gsxrken 08-07-2014 06:38 PM
I think your guy has it reversed. A normally aspirated car likes the small ports to speed up the air column rushing into the cylinder. The better engines can best 100% efficiency in their sweet spot because the momentum of the air column causes it to keep moving into the cylinder even as the piston is rising. Bigger ports kill this effect- see the Ford Cleveland 4V cylinder heads as example.
Whereas the turbo is creating another atmosphere of pressure, so the pressurized air is going to want to go anyway, as the delta between the vacuum in the cylinder and the pressure in the manifold is greater than in a N/A situation. Bigger ports mean more volume, and less heat as the fan can move more into the cylinders without it packing up in the intake system waiting to get in. The more air, the more fuel... this is more important than the pressure or speed of less air and fuel.
But's that's all bench racing. Can't help you with the dyno proofs and I doubt you'll find a guy that had enough willpower to ONLY widen his ports and do nothing else while he was in there. Maybe Chuck Norris could.
kenikh 08-07-2014 07:00 PM
I decided not to port my heads. I'm going for off the line perf, where velocity is everything. Also went 98mm 8.5:1 pistons, mod-SC cams, k27-7006, euro exhaust, twin plugs, stock ports, Andial IC, Andial 8:39 R&P. Not 100% ideal...Rarlyl8 headers and a GT35 would probably be ideal, but close enough to rip out your eyeballs off the line and still get close enough to 400CHP to make me happy. My other cars are early 2L, so needed to go entirely in the opposite direction. :D
Will know for sure in the coming weeks. The motor is going right as I type this.
gumba 08-07-2014 07:59 PM
Yes, wishful thinking that someone would do the one mod, then dyno it. I was curious as a best bang for the buck mod.
kenikh: So by not porting your getting better off the line performance because the a/f is moving faster into the heads?
gsxrken: Porting gets you less heat, and more a/f in the higher rpm range?
911nut 08-07-2014 08:06 PM
Yeah, but until enough boost is developed, the turbo engine is running in n/a mode and not as efficiently as a n/a engine with a typically higher compression ratio. When there is enough boost then you have to worry about the choke point of the small intake ports.
kenikh 08-07-2014 08:12 PM
This is best as a long chat, had over many beers. Lots of nuance. For example, I've built a 2.0L 911S with intake port apertures measuring a nominal 39mm. Kicked ass over 2.7s throughout the power band. It was a cubic dollar motor...made 230HP @ 8000 RPM and mad torque down low, especially for a tiny motor.
There are many ways to increase intake velocity. Smaller ports are just the cheapest. As an example, CNC work for said motor above was north of $5K.
RarlyL8 08-07-2014 08:52 PM
We are machining injector blocks now so I will be porting my heads when the engine comes apart for a refresh, however it won't be just to port the intakes. I cannot imagine going to all that trouble and not opening up the exhaust. Velocity builds as the headers approach the turbo so porting the exhaust will allow more power out. Make the air pump bigger then match with a bigger turbo = huge gains. If all you want is a quick squirt of power then keep all the ports small and the turbo small.
JFairman 08-07-2014 09:07 PM
you can also think of it as.. lightening your cylinder heads
http://forums.pelicanparts.com/uploa...1407470468.jpg
http://forums.pelicanparts.com/uploa...1407470485.jpg
http://forums.pelicanparts.com/uploa...1407470502.jpg
opened up to 40mm and port matched.
i donno, it seems to work:)
gumba 08-07-2014 09:36 PM
Back to my bang for the buck question. Is this a worthwhile mod to have done while having a valve job? Are the benefits worth the $1000,(less if you have the stock injector blocks bored out) porting, aluminum injector blocks , match porting the intake. Or, as Brian suggests, you shouldn't do one without doing the other.
I'm not after a quick squirt (too many beers), or big h.p. Since the motor is apart, and while your in there, this offers some kind of improvement?
TurboKraft 08-07-2014 09:36 PM
I'll look through dynos tomorrow, probably have something illustrative and quantitative. In the meantime, here's my $0.02 on the topic.
Bad port work = not worth the money, better to stick with stock tiny port heads.
Good port work = transformational.
So for the purpose of comparison, we'll say the port work is high quality.
Put SC heads on a Turbo, port match the intake, and it wakes up.
Put 3.2L heads on, port match intake & exhaust, and it's a better driver still.
I've never seen any loss in performance and/or drivability from porting open the heads. 36mm seems to be the go-to size thanks to Ruf doing it to his BTR engines, and Bruce Anderson recommending it in his book. But in my opinion, this size was determined because it's the practical limit of the factory plastic injector blocks. Port them further to 38mm, and they deform when you torque the intake manifold to spec. No bueno, so stop at 36mm, right?
We routinely open the heads to between 38mm - 41.5mm. Never looked back at a build with regret and thought, "Gee, I wish I'd run smaller ports on that engine..."
RarlyL8 08-08-2014 04:54 AM
Excellent point about the quality of the port work.
I have read here of a few folks who had their intake manifolds extrude honed while the engine was apart, that being the only modification. None bothered to dyno the engine but all reported a positive butt dyno. You might search extrude hone or intake manifold, the word porting would probably crash the server.
DSPTurtle 08-08-2014 05:58 AM
Are you sure the butt dyno increase wasn't from the reduction of dollars in their wallet insulating their butt from the seat?
Sorry, I couldn't help myself Brian!!! :)
pkabush 08-08-2014 07:43 AM
Thats silly. Clearly it was the the weight savings from lightning the wallet :D
mark houghton 08-08-2014 08:20 AM
Good description!
Cajundaddy 08-08-2014 08:39 AM
In the world of small bore motorcycle racing, cleaning up the intake ports of all flashing and casting irregularities was always a win. Making the ports bigger was a very mixed bag. Volume, velocity, displacement matching, and acoustic resonance tuning all played a role and we ignored one at our peril. Get it exactly right and we could add 2hp to a 30 hp motor. Get it wrong and we ended up with extreme narrowing of the powerband that was very difficult to manage on a race track. YMMV
Edelweiss 08-08-2014 08:39 AM
Extrude honing
We tried it and so I can give first hand information:
We did an engine for a customer and three months later he came up with the idea to try extrude honing. So - ok off with the heads and the customer gave it to a specialised company. Two weeks later we assembled the engine and put it on our dyno.
Result: zero plus hp.
So what I think is, if people refresh their engines and do this extrude honing the same time the butt dyno is reacting on the refreshment not on the honing.
A good head work is rare to find - you have to understand the ports structure and change the shape and sometimes size into the right direction. It must work with the seat and valve design.
Here in Germany there are maybe fife to ten people who I would say they are good in porting a cylinder head.
The others are thinking bigger is always better and they polish and polish and polish.....
To optimise volumetric efficiency you have to give direction to your flow.
So working on a flow bench and just looking for the flow rates can be very misleading.
The next essential is to get the right cam on the port.
I always work with anti reverse steps - on the inlet and exhaust side.
Best reg.
Dirk
https://www.facebook.com/edelweissmotorsport
JFairman 08-08-2014 10:04 AM
When enlarging 2 valve head intake ports it's often best to remove most of the material from the top side of the port around the valve guides and none from the bottom or short side radius. This is so the air flow is lifted up as much as possible inside the port before it makes the turn going over the short side radius so it straightens out as much as possible before hitting the back of the open intake valve.
Some people add a little aluminum to the bottom of the port before the short side radius to lift up the air flow and make a smoother turn over the short side radius so the airflow straightens out more before the intake valve.
When I did mine I didn't reshape the bowl I just smoothed out the casting marks. The first inch and a half or so of 930 intake ports are 32mm and then they get much bigger in the bowl area.
My aluminum injector blocks are 40mm ID so I opened up the 32mm part to 40mm to match up with the injector blocks.
I installed brand new Mahle pistons and cylinders at the same time and the 1976 930 heads I ported and installed had been previously rebuilt with new guides, teflon valve seals, and a fresh valve job and they had been milled down .018" so the compression was raised a little too. I can't say what difference my porting made but it all works really good. I imagine it helps above 4000 rpm.
I smoothed out the exhaust ports a little with the sanding cones but didn't make them bigger.
I've done this kind of stuff many times before on BMW motorcycles and a bunch of BMW 2002 and 635 heads. I have all the tools and Harbor Freight sells boxes of the sanding cones for porting for around $25. The Harbor Freight arbors the sanding cones thread onto break easily from the side loading so I bought some good ones from a mail order tool place and they are much stronger and last.
TurboKraft 08-08-2014 10:13 AM
E-H can do great work.
But man, can they destroy a 930 magnesium manifold.
Or three.
Well documented in another thread. :mad:
smurfbus 08-08-2014 10:26 AM
Glad you brought that up, did not want to go there myself. What is the limit when enlarging the stock manifold block flange?
Edelweiss 08-08-2014 10:29 AM
Port
Hi Fairman,
solid knowledge !
When it comes to the port bowl it is the spot to generate most of the effect.
Sometimes it's reasonable to make one side a little worse to over proportional make the other side better.
The short side is hard to get around the corner - the long sides are flowing anyhow, so I use the long side to give direction to the load.
This makes less good numbers on the flow bench but much better numbers on the dyno.
Since quite a time we use radius valve seat cutting - on BMW motorcycle and Porsche engines.
This was generating a big step after we found out how to exactly machine the correction cut in the combustion chamber area.
Best reg.
Dirk
Edelweiss 08-08-2014 10:37 AM
The shape
Or three.
Hi again Chris,
how is life going ?
I'm currently on vacation in Bavaria - Schnitzeloverkill...
What is E-H doing different ?
Are they changing the shape ? Diameter ? Or just the surface like others ?
Thanks,
Dirk
Tippy 08-08-2014 11:16 AM
I do find it funny in the Porsche world how taboo porting is talked about.
Every shadetree mechanic doing a crappy port job has seen benefits from my experience.
Stick with the original port shape and everything should be ok.
Change the port shape and you're on your on if it will make an improvement or not.
TurboKraft 08-08-2014 11:19 AM
Hi Dirk -- have a nice holiday! Ich habe dir über Nockenwellen gestern angerufen , schicken Sie jetzt eine PM.
E-H is smoothing out the manifold's casting inside, wherever there is flow resistance to the abrasive putty. This same thought process applies to their opening of the ports -- material is removed where there is flow resistance, theoretically increasing flow in an optimal manner. The flow should be matched when the quantity of abrasive material coming out of the port is consistent on all runners (i.e. X kilos of material in Y seconds. The ports are *supposed* to be opened evenly and on-center -- they swear they have tooling/fixtures, and use them...
...but last time we used them they turned a 930 manifold into a magnesium paperweight, making the ports off-center and randomly shaped, plus taking many weeks (months?) longer than normal.
Thoroughly p*ssed off the owner in the process (I think I still have singe marks from the flame job).
Now we do them all on a CNC with hand-finishing. Reliable results.
BUT back to Harold's question about whether it is worth it:
I think so, on an engine running bolt-on upgrades and camshafts.
I wouldn't do it to a 930 with a K27, muffler, and 1.0bar spring -- the money and effort would be better spent on other exterior bolt-on upgrades first.
If the engine has these other things, and the heads are off, and it is a performance build looking for all-around performance -- good torque, power, and response -- then yes, worth it.
kenikh 08-08-2014 01:01 PM
I'd also suggest that the "quality" of port work is more critical in NA engines. Forced induction solves what optimal port geometry attempts to solve: Getting a fully charged intake tract, as close to zero vacuum as possible. Fancy CNCed ports are designed to pressure load the intake tract and accelerate and compress the intake charge, which is no issue for a turbo, except off idle.
Edelweiss 08-09-2014 07:03 AM
Charge it !
Hi Kenik,
this is one way to see it.
My experience:
If you treat a turbo charged engine like a n.a. Engine in first place you will build the better Turboengine at the end.
For example - a big valve always performs out a small valve, if it is done right.
So you can reduce boost pressure and see the same power or keep the boost where it's is and you will see significant higher numbers.
Same with ports and cams !
Chris - what is your opinion ?
Best reg.
Dirk
kenikh 08-09-2014 07:40 AM
^ I completely agree with you as arguing against the laws of physics generally means you lose. �� I'm painting with an intentionally broad brush for simplicity. I do think gains in NA motors are more dramatic.
Tippy 08-09-2014 07:47 AM
IMO, cleaning up casting irregularities, rounding the bowls smoother, and shaping the valve guide boss should always net some benefit.
Making aggressive changes to the overall port shape should only be done with a flow bench.
But then again, what happens when your pioneering design fails?
You gotta paperweight....
kenikh 08-09-2014 08:06 AM
That's why I've always entrusted the pioneering to guys who make a living at it. (that's a little shout out to Steve Weiner and Dick Evelrude).
JFairman 08-09-2014 12:48 PM
Bill at Xtreme Cylinder Heads in S. Florida is the best.
He does CNC machined ports that look and flow amazing.
Video of it: https://www.youtube.com/watch?feature=player_detailpage&v=DyvXsgIPlPU
You can see them on his website.. Xtreme Cylinder Heads And Castings
kenikh 08-09-2014 12:53 PM
Bill's heads are unbelievable... Those raw castings are nuts.
JFairman 08-09-2014 01:12 PM
Yeah I've been to his shop and seen his heads. If he ever designs and builds a new cam tower for them he could change the valve angles too.
