setting timing
Hi
I have a 1988 turbo and I'm having trouble setting the timing. I have two lines going to my distributor advance/retard diaphragm. Which one is the vacuum line? At idle the inner most line if removed has vacuum. Which one should be remove when setting timing at 4000 rpm? Thanks Scott |
Diagram of vac line connections with emission system removed.
http://forums.pelicanparts.com/6025022-post36.html Sorry don't know which should be removed when setting timing. |
You remove both of them when setting maximum centrifical advance at 4000 rpms. |
Thanks for the help.
| All times are GMT -8. The time now is 03:10 PM. |
