Pelican Parts Vendor
BRAIDusa's Avatar
Originally Posted by BRAIDusa View Post
FYI Now available through our host. BRAID 17" BZ Wheel
Paul Eddleston
BRAID Wheels USA
The last Porsche Wheels You'll Ever Need
http://www.pelicanparts.com/catalog/SuperCat/0812/POR_0812_BDYWHL_pg3.htm#item11
Old 10-08-2014, 01:05 PM
Recently fitted these Speedline Ruf's. They're 17x9 (235/45/zr17) up front & 17x10 (275/40/zr17) at the rear.
Puchased from Kenikh.
They're a totally different look from the standard 16" Fuchs.....probably bolder ....less delicate or visually articulated. i'm liking it though!
before
after
Had to replace the stock 26mm spacers at the rear with 15mm spacers (tried adding another 6mm spacer to that but would have needed to roll the rear fenders). Also needed open-ended lug nuts........might install some shorter stud so I can use the closed nuts at some stage.
Currently using the stock spacers up front but getting some rub on the oil cooler shield on full left lock......might look at 40 profile tyres next time to reduce this.
Old 10-11-2014, 12:44 AM
