16Volt's Avatar
The 'official' 930 Dyno Vid Thread
Searched and didnt find one soooo....
Pretty simple:
1. List out the pertinent mods
2. Post your cars dyno run and chart
If you would like I can even post your video on my YT channel if you would like. PM me if interested.
My car:
86 930
Tial WG (one bar spring, unconfirmed)
B&B headers, dual-out muffler, intercooler
044 pumps
337whp/341ftlbs @ 13psi
Capture930dyno by thecrashingdoor, on Flickr
Is there no way to embed YT links on Pelican?
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 09-15-2014, 12:36 PM
speednme1's Avatar
Nice numbers..what are you doing for fuel enrichment?...not enough fuel and you will lean out.
Rey....77 930 "the Mistress"
Old 09-15-2014, 03:12 PM
16Volt's Avatar
No fuel enrichment, thats off the stock WUR.
Old 09-15-2014, 03:26 PM
speednme1's Avatar
a modified fuel head with bigger lines and a BL WUR may build you some protection against detonation...just saying...
Old 09-15-2014, 04:22 PM
1979 - Stock except for later heat exchangers. Emissions stuff is disappeared and wastegate goes to wastegate muffler.
Peak power was 285, peak torque was 295.
They said their boost gauge was off, I don't remember if he said high or low.
Old 09-15-2014, 04:24 PM
Registered turbo addict
Menmojo's Avatar
Great idea for a thread!
Let's see more.
Here' my 89 930 monster on the dyno.
733rwhp/655lb torque @ 23psi
PORSCHE 89 930 3.4 DYNO 733RWHP - YouTube
Old 09-15-2014, 07:25 PM
3 restos WIP = psycho
kenikh's Avatar
Nice numbers Eric.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-15-2014, 07:34 PM
Let's see more.
Hello Menmojo,
Bravo, your engine has an incredible power, you could give me a small description of your preparation engine? (ECU, trigger wheel 60-2/36-1, collection internal diameter of escape, turbo, cams, syringe (cc) of fuel, ignition, sensors etc.) I have Ruf 3.4L but it is not "still" in EFI, when I see the results of your car that gives envy(urge)! Thank you.
Old 09-16-2014, 01:03 AM
Crotchety Old Bastard
RarlyL8's Avatar
Good thread idea but without guidelines/categories it will get messy quick.
16V it looks like you could use a WUR rebuild, there is power on the table from 3000-4250.
Zakthor has a beautiful fuel curve. Please tell us if your WUR is stock of modified.
Old 09-16-2014, 04:02 AM
16Volt's Avatar
Here is one of your runs Eric.
Old 09-16-2014, 06:28 AM
I believe it is stock and never adjusted. I just went through all the records and there's nothing about the WUR.
Awesome, thanks! That was a close one, you almost had me uploading something to youtube.
Old 09-16-2014, 07:58 AM
16Volt's Avatar
Ha, no problem, I am trying to edit it down a bit but the YT editor sucks.
Old 09-16-2014, 08:38 AM
Menmojo's Avatar
Pat RUFBTR here are the basics of the build:
Heads ported & flowed (Dave Jarvis)
Engine Management Tec3-r Full Sequential
Electromotive crank fire ignition
Twin Plug Heads
Garretson Turbo Ceramic Ball bearing
3.2 Carrera Manifold/ported and polished
Custom Equal length Headers
95lb Injectors
Pauter Rods
Racing Valve Springs
O-ring Heads
Andial 3.4 Cylinders & Pistons 7.5/1
Greddy b boost controller
Tial 60mm Wastegate
Aeromotive Eliminator Fuel Pump
Custom Intercooler (Essa Tech)
ARP Cylinder Studs
ARP Rod Bolts
Custom grind Cams
Wide band A/f gauge
Borla XR-1
Old 09-16-2014, 03:19 PM
Chain fence eating turbo
^^^^ our engines are almost identical minus my stock cams.
Holy crap you made some big power.
What RPM did you have to turn it? I want to stay at 6750 tops due to stock rods and heavy Max Moritz pistons.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-16-2014, 07:58 PM
Menmojo's Avatar
Max hp @ approx 6100-6200 rpm on the Dyno.
I have the redline set at 7000 rpm.
On the street I keep the boost down to 1 bar.
@ 1 bar I'm pretty sure it's approx 600 hp.
I want to make sure this engine lasts.
Old 09-16-2014, 08:36 PM
Thanks you Menmojo! I also had to put a big Wastegate precision turbo PW66 to regulate my turbo (P67 / 66 AR 0.82 with exit 3 " towards the intercooler), I did not want to put 2 Wastegate. If I cross(spend) a day in EFI I do not know if I have to put a trigger wheel 36-1 or 60-2, I know it nothing about this subject! Given that I make my engine at the moment I would in advance like to install(settle) the maid to trigger wheel. Still bravo for your car!
Patrice (France)
Old 09-17-2014, 10:25 AM
That is insane power for such low RPM.
Old 09-17-2014, 11:06 AM
930T Owner
Hams930T's Avatar
Twin Plug Heads
95lb Injectors
Pauter Rods
O-ring Heads
Tial 60mm Wastegate
ARP Cylinder Studs
ARP Rod Bolts
Custom grind Cams
Wide band A/f gauge
Borla XR-1
The part that I dig the MOST about your build is that I see the a/c compressor on the right side still there! Bravo sir!
Chris.
Hams930T
2017 Turbo S
Old 09-21-2014, 03:15 PM
Pimpim's Avatar
Send a message via MSN to Pimpim
Here is mine on the mine
Mappning 445WHP Porsche 930 MaxxECU - Maxxtuning AB
Old 09-23-2014, 04:50 AM
I'll play...after many hours of dyno tuning...and AWD, don't see that often in this forum on these old Porsches
Old 09-25-2014, 07:47 PM
