Tinkering Pays!!
mooney265's Avatar
Rear Fuse Box Diagram
I'm working on putting together a Fuse Diagram for the front and rear fuse boxes. I'm about done with the front.
Having a little difficulty figuring out which fuses and single relay is in the rear. When I consult my manual, it states:
Relays in Rear [I only have one - see blue circle]:
1. Rear Window Defogger ??
2. Manifold Pressure Limiting Switch and Air Sensor Contact - - I'm guessing it's this one...
Fuses in the Rear [I have 3 - see yellow circle]:
1. ?
2. ?
3. ?
Can someone[s] identify the 3 Fuses and single Red Relay for me? thanks, Shannon
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 09-16-2014, 02:43 PM
Tinkering Pays!!
mooney265's Avatar
Thanks to BillJam [Bill James], I was able to modify his design slightly to fit my car. Still working on it, but here is a sample:
Old 09-16-2014, 03:18 PM
Certified User
billjam's Avatar
Not sure about the fuses, but ...
Pictures in the manual for earlier cars have red relay #3 in the same hole as yours.
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 09-18-2014, 04:45 AM
Tinkering Pays!!
mooney265's Avatar
Yeah, you can see the remnants of the double-stick tape where I had originally mounted the BL RPM Switch. So, I moved the relay up one notch.
Anyone on the three fuses? Thanks!
Old 09-18-2014, 06:22 AM
These diagrams are clear and very nicely done, do they exist for a 1986? If so, I'd like to purchase one. If not, does anyone have a front fuse box wiring diagram for 1986? I've got to find some power for a WEGO and am looking for where to tap in.
(sorry for the OT) - thanks.
Old 10-07-2014, 08:29 AM
Tinkering Pays!!
mooney265's Avatar
Tonger,
BillJam provided a template in Microsoft Visio Format. You'd need to have a copy of this program - It usually comes with a full-blown version of MS-Office.
I did, so was able to modify it to 1979 Specs. I'm sure Bill won't mind if I send you the Visio Template.
Just send me a PM with your email address. Shannon
Old 10-07-2014, 10:23 AM
Banned
I just emailed one to you.
Old 10-07-2014, 10:59 AM
Uncertifiable!!!
Uwon's Avatar
Shannon, have you figured out what the 3 fuses are at the rear as I have a little problem with my build?
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 10-07-2014, 01:40 PM
My car has a wildly different layout to this. (76 930).
I've been looking into this and I'm on the verge of guessing they just slapped what ever they wanted in there on a day to day basis?
I am yet to find a wiring diagram that comes close to my fuel pump wiring?
My 3 rear fuses relate to A/C?
Old 10-07-2014, 02:05 PM
Garage Queen
PorscheGAL's Avatar
Ok, went out and pulled the cover off the fuse area in the engine compartment. My cover has the fuses labeled in the inside of the plastic cover. It is imprint in the plastic not a sticker.
1. fan pass compartment 16A
2. fan engine compartment 25A
3. rear window heating 25A
Stephanie
My minions:'86 911 Targa 3.4, '87 930, '05 Lotus Elise,
'19 Audi RS3, '13 Focus ST, '16 Focus RS
Old 10-07-2014, 02:14 PM
I wonder if that is a carryover part from a Carrera? 930s don't have engine compartment fans.
1987 GP White 930
1977 Ford Bronco
Old 10-07-2014, 02:40 PM
Garage Queen
PorscheGAL's Avatar
I agree. But I have a 86 911 and the fuses are for the heater blower and the rear defrost. Would be interesting to see what other people's covers say.
Stephanie
Old 10-07-2014, 03:02 PM
My fuse cover reads...
1- Sportomatic
2- Fan
3- Rear window heating
76 930
I have no sportomatic, no engine fan, and no rear window heating. Yet all the fuses are in place?
Old 10-07-2014, 03:15 PM
Banned
My cover reads identically to yours (I have a 1987 Turbo) and the "engine compartment fan" fuse holder is a dummy (no wiring to it and obviously, no fuse needed in the holder).
Old 10-07-2014, 04:11 PM
Banned
1- Sportomatic
2- Fan
76 930
Are the fuse holders wired? Like I mentioned above, my "engine compartment fan" fuse holder is not wired.
Old 10-07-2014, 04:12 PM
Tinkering Pays!!
mooney265's Avatar
All of mine are definitely wired. To answer an earlier's post; No, I have not figured these out.
I think I'll break out the wiring diagram for my car and try to decipher it. If that doesn't work, I'll just turn on ignition, pull fuses and see what I see. Then, start car, pull fuses and see what I see... Based on earlier posts, I'm betting one is rear defrost??
Was hoping someone had already figured it all out ???
Old 10-07-2014, 04:50 PM
I have a 81 with three wired fuses in back. IIRC one is for the rear wiper. Can't recall what the other two are for. I'll check it out and report back tomorrow.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 10-07-2014, 07:15 PM
16Volt's Avatar
Dog piling onto Shannon's old thread here.
I took his/Bills diagram and added the designations off my 86 930 panel.
Capture86_930
My rear panel cover appears to have been trimmed so I cant see any of the designations. Additionally the rear cover had a 911 P/N of 911.610.105.04 which makes me question its authenticity.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 01-04-2015, 12:24 PM
16Volt's Avatar
According to pelican that above P/N is correct for a 930 rear panel cover:
1986 Porsche 911 Turbo Coupe - Switches, Motors, Relays, Fuses & Wiring - Page 1
Old 01-04-2015, 12:57 PM
I had no end of trouble looking for a 76 wiring diagram. When I found anything close, it was still different to what I was looking at.
After going through and working it out myself, I discovered that my car was one of the first 400 built. This means it is has 1975 wiring.
Old 01-04-2015, 02:37 PM
