Help with Adjustable WUR
Anybody in the Atlanta area who can help me sort out my fuel issues? I just got my top end done twice. Found a broken headstud during the break-in period and they rebuilt it again. I just got the car back but it idles around 12AFR and at cruise it gets up to around 15.2. My mechanic said that's ok but it's starting to backfire and run a bit rough. I did have the WUR rebuilt to a modified WUR by Brian at Rarelyl8 as well as the fuel head. Also new injectors. My mechanic has tried countless time to smooth out the AFR but at this point I really don't think he understands the modified WUR. He believed the fuel head was an issue and swapped it out with a good one but the same issue remains. My mechanic is a great guy but I got to try something different to get this resolved.Trying to figure out how to work the modified WUR. Anyone in the Atlanta area want to help a guy out?
Thanks,
Sean
Old 09-18-2014, 10:01 AM
T77911S's Avatar
who is doing the top end? is he a porsche guy?
you need to post the year and perhaps the setup
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-18-2014, 11:59 AM
Sure. Here's my setup:
1988 930S
3.3 liter / heads increased to 38 / port and polished
B&B Headers/Garrett full bay intercooler/GT35R turbo/Rarly8 dual out muffler/964 Cams/rebuilt fuel head for increased flow(temporarily replaced with stock fuel head for testing) & Adjustable WUR
Got the top end rebuilt with new turbos / fuel head & adjustable WUR / exhaust / injectors / clutch / clutch assembly / other items. This was done by a well known mechanic in the area with many years of Porsche experience.
Old 09-18-2014, 12:30 PM
I've seen your car around a few times when I worked in Peachtree Corners and a couple of times at Caffeine and Octane. It looks great, sorry to hear it is running rough.
1987 GP White 930
1977 Ford Bronco
Old 09-18-2014, 12:40 PM
dos531's Avatar
If the wur is set up like the BL adjustable ones I have a scanned manual that was sent to me by a member here. I'd be happy to share if if it will help. If you want it just message me your email and ill send it over.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 09-18-2014, 12:58 PM
Thanks. It's been a rough ride so far. The cars been in the shop 10 out of the past 12 months. And more than half the time I've owned it. Probably spent more time and money into my cars then my kids....but not my wife . She's in a whole different league. If my wife is reading this...just kidding. But with that said, still love my car and plan to keep it for a while.
Old 09-18-2014, 01:11 PM
T77911S's Avatar
i had to cut the first one short.
i would set the warm CP to spec for the fuel head you are running. then i would adjust the idle mixture to 13.5. then i would check the cruise AFR and how it drives at a STEADY speed at around 2500 rpm and 3k. if the AFR is still lean, i think you may have an air leak. you dont need to go on boost, just check steady cruise speed for now.
mine runs like yours. rich idle, lean cruise and does not run smooth at steady speeds. i have been fighting air leaks at the intake.
just curious, plastic or aluminum injector blocks?
O2 sensor?
RACE CAR:: sold
Old 09-19-2014, 03:53 AM
