b930's Avatar
Speedhut GPS speedometer install
Thought you guys might like this. I was looking for a KPH speedometer for my UK (to Australia) import. Decided to go with this. Its very cool actually, has some nice features like highest speed recal with pointer, GPS accurate speed, 0-100, 1/4 mile times calculation, GPS accurate time, altitude etc as well as milage total, and milage resttable.
Fits pretty nice but I do need to trim the ring behind the unit so I can fit the proper grommet. Very easy wiring, GPS receiver is magnestised and stuck under front hood.
Cheers.
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 09-30-2014, 01:04 AM
jsveb's Avatar
Looks cool. Can you provide some more info on which model you chose?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 09-30-2014, 08:56 AM
b930's Avatar
Hi
Its the 4" GPS model, you can get them with all kinds of different face, text and pointer designs, and can also get them with indicator and full beam lights in (I have one in a Mk1 escort with that set up). Check out the speedhut website as all the info is there...cheers.
Old 09-30-2014, 09:24 PM
