Unhappy broken clutch cable mounting point
the ear on the tranny that holds the clutch cable broke. found a bracket from wevo but it's for a 915 gear box and won't work on my 1983 930 4 speed gear box. does anyone have a fix for this? any pics or ideas would be greatly appreciated. thanks in advance, mick
Old 10-09-2014, 03:46 PM
Jeff NJ's Avatar
You mean this? This picture doesn't show the turbo version, but the part description says it is.
Pelican Parts - Product Information: 930-116-713-06-OEM
1988 930 Venetian Blue
Old 10-09-2014, 07:48 PM
TurboKraft's Avatar
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 10-10-2014, 08:28 AM
in the pic chris posted you can see where the clutch cable is captured by an ear off the bottom of the tranny. the outer part of thatear broke. they make a bracket for the 915 tranny but i haven't found one for the 930 4 speed. talked to wevo and rothsport but still don't have fix. any suggestions?
Old 10-10-2014, 03:49 PM
beancounter
jwasbury's Avatar
I would think you could have some material welded on to the case to replace the broken "ear" bit
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 10-10-2014, 03:53 PM
TurboKraft's Avatar
Remove engine and gearbox.
Separate gearbox, drain, clean. Photograph serial numbers.
Heat housing, weld up, grind to shape, drill hole to size.
Take this opportunity to wipe down the engine, address anything that's a PITA to fix with the engine in.
Fill, reassemble, install.
Or you could fabricate some bolt-on doodad in the meantime.
Or convert it to hydraulic.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 10-10-2014, 05:23 PM
Chris, how involved is it to convert to a hydraulic clutch? it's gotta be easier then pulling engine and trans.
Old 10-11-2014, 03:00 AM
It would be ALOT more work and expense. You'd have to change the pedal cluster to one that uses a clutch slave cylinder and run hydraulic lines too.
I've had BMW's with hydraulic clutches that use expensive ATE or FAG master and slave cylinders that are poorly made these days in who knows what country by the lowest bidder and don't last. They are complicated and high maintenance and will probably leave a nice big carpet soaking puddle of brake fluid on the driver side floor when the slave cylinder seals takes a dump after a little while.
I so much prefer the simplicity and low cost of an old school... mechanical clutch cable. They just work, the clutch pedal feel is great, and they last a long time.
Old 10-11-2014, 05:16 AM
It happened to a 930 race car I had. The shop welded it. Still OK.
Anthony @ Voitureltd Bayside WI.
Old 10-11-2014, 07:27 AM
thanks for the info guys. I think i'll try to make some sort of bracket. welding seems like a lot of work having to remove engine and tranny.
Old 10-11-2014, 05:11 PM
7.0:1 > 11.3:1
I saw a repair on a 930 trans which was a simple block of aluminum with two bolts holding it to the part number lug and a hole for the cable to go through.
Old 10-11-2014, 06:27 PM
jim, thanks for the idea. i'm going to see if i can duplicate that.
Old 10-12-2014, 12:03 PM
proffighter's Avatar
This might help:
Clutch Adjustment and Pedal Question
http://forums.pelicanparts.com/uploads19/ClutchBracket1321687444.jpg
or this one aftermarket:
Roland
930 Turbo '81 Too many modifications to list
Old 10-13-2014, 01:59 AM
Hmm I uploaded pic, but it's not shown???
Here's the link to the thread then:
Broken Clutch Cable Mount on 915
Roland
Old 10-13-2014, 02:04 AM
roland, i appreciate the info but i have a 930 4 speed nota 915. that bracket won't work for my tranny. i wish it was that easy. thanks for the cthought though. mick
Old 10-13-2014, 12:55 PM
Mick
Of course it won't fit on a 930, but you can make one easily which does. Posted to show how it can be solved...
Good luck
Roland
Roland
Old 10-14-2014, 01:54 AM
Mick:
Here's what I did.
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
Old 10-14-2014, 06:21 AM
