CIS fuel head repair kits
While clicking around on ebay I came across these fuel head repair kits. Looks like they're for cast iron fuel heads and the kit packages say made in USA.
FWIW, there's posts with pictures on the tech forum where people have rebuilt these things at home.
Porsche 911 3 3 Turbo 1977 1988 Repair Kit for Bosch Fuel Distributor 0438100037 | eBay
Porsche 911 3.0 Turbo/ 928, Bosch Fuel Distributor Repair Kit Mercedes 450 SL
Old 10-15-2014, 07:18 PM
Crotchety Old Bastard
RarlyL8's Avatar
Bosch doesn't sell repair kits to the general public.
Old 10-15-2014, 07:48 PM
Than makes this place most excellent.
With the new technology they are using the stainless diaphram they cut may be better than what bosch made 35 years ago. I've seen pics of the old metal ones with dimples bent into them under the flow adjusters.
They have this download link for rebuild instructions in PDF format.
http://www.cis-jetronic.com/public_doc/07.3-0997-06.pdf
Old 10-15-2014, 09:47 PM
umop apisdn
I have a number of their kits here and can vouch for the quality. Very nice gear for a very small price. Just requires a brave soul to install
They also do an alignment pin set that is definitely useful during reassembly.
search through their store for your FD part number as they have alloy head kits as well
1981 928S 4.7 ROW with KE3-Jetronic
"Be the man your dog thinks you are."
www.FrankenCIS.com
Old 10-15-2014, 11:53 PM
that is aftermarket...
...but: they say their material can handle the crappy exx fuel. My fuel head (alloy) was damaged by bad fuel. the o-rings were weak and partial gone. i ordered a set and mounted it. did not use it now. it sits here and waits for my engine to be back in car. bosch only deliveres complete heads. so i did my damaged head and will try in spring. costs a fraction of the excange price. rhin it is worth a try.
Old 10-15-2014, 11:57 PM
T77911S's Avatar
i might consider it for $30-$40. i would also just replace the shim. pulling the center barrell out that the pin goes in is just asking for more trouble. IMO.
if i put the kit in and i still had running problems i would always wonder if the head needed to be calibrated for fuel flow.
i think the head needs to be calibrated for a certain amount of fuel flow for a given movement of the center pin. the ports also need to be balanced.
i have checked the balance on my head and it was not too bad. i did do a minor adjustment on one port. its such a pain in the rear end to do with hard lines. having to deal with fuel leaks and fuel smell is not worth it.
i am sending mine to flow tech in a few months. i still get VERY odd AFR's depending on what gear i am in, the RPM and where the mixtrure screw is set.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 10-16-2014, 02:21 AM
This kit is very attractive seen its price(prize), however once all the replaced joints, it is necessary to be capable of settling / balancing well the debit(flow) of the fuel, it is not a small matter!
Is there also a kit for the restoration of the WUR?
Old 10-16-2014, 02:37 AM
yo lo compre y no funciona, hay que tener herramientas especiales, al final me lo repararon en la fabrica Bosch, 1000Euros.
Old 10-16-2014, 10:23 AM
