Norm K's Avatar
Question on Rubber Intercooler Seals
Okay, so this is a silly one ... it's been seven months since I disassembled my engine and I can't for the life of me figure out where one of the orange rubber seals go (sorry, I'm sitting at my desk and don't have pics). It's not one of the O-rings, or what Porsche calls Round Seal, but rather one of the cup-shaped seals Porsche refers to as a Sealing Ring.
I know there's one that sits inside the top end of the pressure pipe and another at the bottom. The larger of the two - the one at the top - is right at about 3" OD, I didn't measure the bottom one.
Anyway, to the seal in question; it measures 3.5" OD, much too large to fit inside either end of the pressure pipe. I thought perhaps it might between the intercooler and the Bypass Valve but the Porsche parts books I have don't show such a thing.
I've rebuilt this entire engine from the main bearings up (and out) and yet I'm hung up on what seems the simplest of items.
Sure could use some help (along with some well-earned ribbing).
If the Army and the Navy
Ever look on Heaven's scenes;
They will find the streets are guarded
By United States Marines.
Old 10-22-2014, 09:06 AM
j930's Avatar
i bet someone will put up a diagram. can quite picture any seals other than the orange ones in the pipe and the special sleeve that joins the down pipe and the turbo. sorry i am of no help
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-22-2014, 12:56 PM
Crotchety Old Bastard
RarlyL8's Avatar
There is a large black seal that fits on the outside of the intercooler / up pipe junction. The IC sits on it. It is not orange so may not be the one.
Old 10-22-2014, 01:12 PM
oilonly's Avatar
You say orange and cupped shaped, could be the tin seal for up or down pipe so no air enters through the tin from underneath and not a seal for boost purposes.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 10-22-2014, 01:48 PM
I have an 81 but I no longer run the stock i/c. I do still have all the parts though. None of which contain the cup shaped seal your referring to. My car didn't come with any seals around the tin so, perhaps I'm missing that
Sorry I can't be of more help. Hopefully someone will know WTF your talking about
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 10-22-2014, 03:17 PM
speednme1's Avatar
this might help
Rey....77 930 "the Mistress"
Old 10-22-2014, 03:47 PM
I think you are referring to the tin seal for the up pipe.
Old 10-22-2014, 04:47 PM
Norm K's Avatar
Originally Posted by speednme1 View Post
this might help
Looks like no. 3, the Sealing Ring. What's got me confused is that (I believe) no.3 is the seal that fits into the top of the pressure (up) pipe. I have two of those that are 3" OD. The ring I'm referring to is the same shape, but it's OD is 3.5".
Old 10-22-2014, 05:20 PM
mark houghton's Avatar
I concur. The key is the orange color. If black, Brian already pointed to the up-pipe-to-IC junction outer sealing ring (which in my mind was nothing but window dressing and served basically no purpose at all). Orange says it's the tin junction.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-22-2014, 06:31 PM
Alexm930's Avatar
nkowi, the seal you refer to is # 20 on this diagram. It fits as you see on the bottom of the charge pipe. Hope this helps. I changed mine some months back as well as all the other o-rings.
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 10-23-2014, 04:33 AM
Norm K's Avatar
I wish you were correct, but that seal (no. 20) is much smaller. Thanks.
Old 10-23-2014, 06:34 AM
...sounds like the seal between turbocharger and neck to intercooler...orange...cupped...
Old 10-23-2014, 07:04 AM
Norm K's Avatar
I have two of those - each 3" is OD. The seal in question is 3.5" OD.
What's interesting is that if you work it into place it actually fits pretty well into the top of the charge/pressure/up pipe. I'm beginning to wonder if there are two different sizes made for the same application.
Old 10-23-2014, 07:13 AM
