Help me ID this oil line?
I'm having trouble finding this guy on our host catalog. Can anyone help me out? Tired of the leak
'87 930
Old 10-25-2014, 05:37 PM
Originally Posted by onboost View Post
Thanks a bunch! I'm gonna order them both and get it done this weekend! Will update thread with some pics
'87 930
Old 10-25-2014, 08:32 PM
Tonight I got the car up and started degreasing the general area. I'm hoping I can get it clean enough to figure out what other lines need replacement.
I think this guy could be suspect but I'm not sure yet..
Anyone wanna help out on ID'ing again?
Does anyone know if there are any washers or anything that go between these lines and the tanks / hardlines ? This is what I have in the cart so far..
'87 930
Old 10-26-2014, 09:28 PM
j930's Avatar
the first picture is showing that large oil return line that connects to the hard pipe that runs along the back end and make that turn toward the front. if the same as my car it goes to the front oil cooler. if thats the one its a pain in the but. i removed the thread end, took a dremel to the end toward the passenger door and removed the pressed collar. there are a few shops here local in phoenix that sell that line and i bought some nice heavy duty adjustable clamps to reattach the line on the upper end. the lowered is still threaded on. we may not be talking about the same line? if so and you need help drop me a email or PM.
John
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-27-2014, 06:05 AM
You will have to spray some engine cleaner on everything thats wet with oil and hose it off with water. Then drive the car a little and look for where the fresh oil is coming from to know whats leaking.
There are no sealing washers on any of those lines, they're tapered conical compression fittings and you could try loosening and re tightening them a little bit and see if that helps.
Make sure some oil or grease is on the threads so they tighten on easier and don't damage the male threads on the oil tank.
If you want to save some money it's not hard to remove the rubber part of the long return line that may be the leaker and clamp on a new section of hose like this.
The rubber part of that hose was slowly leaking where it attached to the oil tank when I got my car in '06 and I replaced it with this stainless braided hose and two small t-bolt clamps around 8 years ago and it's never leaked.
Old 10-27-2014, 06:47 AM
Thanks guys!
I'm gonna take it over to a local place that rents lifts and go all out on the cleaning / rinsing so I can be sure of what I'm replacing before I drain the oil. I also have an exhaust gasket project I'm gonna tackle at the same time as line replacement so my goal is to get everything I suspect leaking on hand so I can do it all in one shot or close to that
@JFairman That stainless section looks very nice I might be going that route depending on what else I find! Is it just me or is your line routing slightly different? My car is an '87 and the line between the hardline that runs around the back of the engine and the external valve that opens to let the front cooler begin circulation seems to be routed differently? I guess its the sending line I'm referring to.
'87 930
Old 10-27-2014, 12:48 PM
Large Member
krasuskyp's Avatar
Yes, Jim's got headers so he's running the "early" oil line... you've got the later one that loops around / under the rear of the engine, that gets in the way when you install headers.
And definitely heed his advice regarding the tank fitting, mine buggered the threads upon REMOVAL, and I had to finagle a work around to ensure it sealed.
also, it's quite possible but hard to really tell from your picture that any oil spilled during fill-up or oil filter removal could easily have drizzled down through the holes / seal in the tin and gunk up all of which resides below - check the right rear frame rail in the engine bay for tell tale signs...
good luck
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 10-27-2014, 02:24 PM
good luck
Thanks Krasuskyp! That makes a lot of sense reg the line routing. I will try to get some pics of it on a lift after its been scrubbed out then run for a bit.
'87 930
Old 10-27-2014, 05:41 PM
I got it on a lift and spent and hour with degreaser and rags.
I drove it home which is only about 1.5 miles and the only spot it was leaking was the thermostat/front cooler feed line where it meets with the hardline.
A few days later I drove it for a while to really get it up to temp and It looks like the valve cover gasket is leaking and also the cam chain cover gasket?
'87 930
Old 11-01-2014, 07:06 PM
onboost's Avatar
I started to suggest in my reply that you check the valve cover gasket but really couldn't tell from you pic.
Also, check the cam tower oil line above that chain box.. it could also be leaking Between that the larger line below, and the vc gaskets, it could be oil that just being moved with airflow etc.. also check the nuts on the chain box to ensure they're not loose.
RGruppe #180
Old 11-02-2014, 01:11 PM
