j930's Avatar
17 inch fuch offsets
looking for someones advice on how much offset i need for the fronts on my 84 930. the wheel sit a little to far inside the fender right now. i think 10mm seems about right but want to know if someone has any input. i bought the 17 inch fake linea fuchs.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-27-2014, 10:15 AM
It really depends on the hub/spacers arrangement you have on the car. Keeping the OEM spacers require certain offset, removing them changes that. But, I believe you got your own answer 10mm spacer from whatever is there now... I kept the OEM spacers on my 78 when installed the 17s, so if you want, I can get you my wheels offset.
Old 10-27-2014, 10:28 AM
j930's Avatar
sure would like to know, thanks
John
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-27-2014, 12:37 PM
Take a pic of your front hub with the wheel off. Put a tape measure up next to it so we can see what you have.
63 356 So Called Outlaw
76 930
Old 10-27-2014, 01:47 PM
I have one nicely made 10mm spacer I'd like to sell. They usually do travel in pairs.. but this one's all I got.
Pelican Parts used to sell them, maybe they still do.
It'll fit in a padded USPS priority mail envelope so I'd sell it for $35 shipped with tracking number to anywhere in the USA.
Old 10-27-2014, 04:08 PM
Driver
Noah930's Avatar
These were the figures Zuffenhaus supplied me for the "Zuchs" on my car:
Front, 9x17, ET 30, backspace 5.68
Rear, 11x17, ET 17, backspace 6.18
*Have not measured myself to double-check.
1990 Black 964 C2 Targa
Old 10-27-2014, 05:46 PM
j930's Avatar
Thanks for the input. Jfairman I appreciate the offer but I need 2... I found some 12 mm ones today here in pix. They bring it out about perfect but I am only getting about 3.5 turns on the studs. The guy I bought them from said no less than 5 turns. So I guess I will need to replace the studs now. Always something. It appears those are not easily removed. I have never had to replace them on any car.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-27-2014, 07:25 PM
What are your present offsets?
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 10-27-2014, 08:37 PM
10mm spacers might get you to that 5 turns.
Bryan O.
77 930
88 Carrera cab
14 535i M Sport
Old 10-28-2014, 12:18 AM
Do your rear Zuchs wheels use the factory wheel spacers or do the spacers get removed?
Thanks for the info!
Old 10-28-2014, 03:45 AM
John
No problem but I'm traveling... will get you mine later this week.
Old 10-28-2014, 05:15 AM
j930's Avatar
ok, so i took the 12mm back and i am going to try 7mm and see what that looks like. if no good then i will be replacing the studs
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-28-2014, 12:58 PM
Driver
Noah930's Avatar
I kept the stock spacers on the rears. My car is an '87. Otherwise stock.
Old 10-28-2014, 07:24 PM
FrenchToast's Avatar
May be obvious, but don't forget to make sure the lugnuts still have full engagement on the studs!
Old 11-01-2014, 04:59 PM
j930's Avatar
so the 7mm get it close to a good look. I'm on the fence. i may do the 12mm and put longer studs on.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 11-02-2014, 04:58 PM
