jopo911's Avatar
930 Warm Up Time
How long does it take your 930 to "warm up" before you start your drive? Mine takes a good 5 minutes before everything settles down and runs smooth. Starts right up, but AFR about 15, then slowly goes down to about 10.9 and slowly rises to 13 to 13.5. Just adjusted cold and warm pressures, and installed new rear fuel pump. Also disconnected Lambda O2 sensor. After warms up, runs fantastic! Is this normal?
Joe
1986 Black on black 930
Kokeln IC/ 1 bar spring/European Fuel Head
GHL Exhaust Dual Exhaust, Wevo shifter and coupler
935 Front Air Dam, Forgeline wheels
Old 10-30-2014, 02:47 PM
oilonly's Avatar
Start up for me AFR is at high tens then slowly rises to high 13's after 3 or 4 minutes, this would be on a 70 degree day. Don't have that 15 number like you do on initial start.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 10-30-2014, 03:15 PM
gavinc69's Avatar
Same here, mid 10's for several minutes gradually going up to mid 13's. Starts rich and gets a little leaner as it warms.
After its really warmed up, driving for 20 mins say, AFR reads 13.8 or 13.9
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 10-30-2014, 04:35 PM
Norm K's Avatar
Ditto. Rich when cold (AFRs in low 10s) gradually and steadily moving up to 13.8/13.9 as things warm. I've started my car with temps in the teens and at over 100 degrees and pretty much everywhere in between. Ambient temperature seems to affect only the time it takes to reach the high 13s. Don't recall seeing AFRs in the 15s at initial start up.
If the Army and the Navy
Ever look on Heaven's scenes;
They will find the streets are guarded
By United States Marines.
Old 10-30-2014, 05:40 PM
mark houghton's Avatar
Your AFR's are too high for a "normal" cold start. WUR might not be working quite correctly. But then, it does eventually go down to 10.9, which is closer to what you should be seeing stone cold. Frankly, as long as she's starting easily and maintaining idle, then why worry about it.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-30-2014, 06:34 PM
Ditto. Then when the lamba system kicks in, it goes to 14.7...
Bo
Old 10-30-2014, 06:37 PM
