Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
TurboKraft's Avatar
I haven't found any aftermarket AOS units better than the factory. The factory part (made by Purolator!) vents the breather air in tangentially so that any oil vapor will swirl around the outside wall and condense. Liquified oil runs out the drain hole back to the oil tank. There's an interior baffle to prevent air from coming in the side port and going straight out the top port.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 01-03-2018, 08:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
Rocket Scientist
Well, here is some useless advise, use the GT1 oil pump. It has a bigger scavenge section. That will pull down the crankcase pressure. All you have to do is tear open the engine.
Old 01-04-2018, 04:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
