Oil Level Gauge
My oil level gauge died suddenly. It was working perfectly until one day it stopped showing anything and sits at the bottom of the scale (low level) permanently. With ignition "ON" it moves from the position "dead bottom on the peg" up a tiny amount to sit at the bottom of red and stays there all the time.
So, I suspect the signal is not coming from the sensor.
How to check if the sensor is OK? I know where it is and maybe some wire lost contact. How to check this?
If it is OK, how to test the gauge itself?
Old 11-07-2014, 02:06 PM
T77911S's Avatar
this may help.
Oil Level Gauge question
remove the wire from the sender. the needle should max out. ground the wire, needle should now go to minimum. if the needle does not move problem is wiring or gauge. most likely wiring.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-10-2014, 06:07 AM
