930 will not stay running.
I have an 81 930 that will turn over but will not stay running. It cranks then quites, cranks then quites. It will run about 3 seconds. What do I need to do to fix it.
Old 11-16-2014, 05:57 AM
Banned
outta gas?? bad fuel pump perhaps
Old 11-16-2014, 07:45 AM
It has gas and the pumps sound like they work
Old 11-16-2014, 10:08 AM
Strygaldwir's Avatar
It is a little difficult to tell without more information, but I had similar symptoms. Mine would start, then die in about 3 seconds. I found that if I held the metering plate down, it would continue running. I then got a pressure gauge to measure the cold control pressure. This show WAY high. I took the Warm Up Regulator (WUR) out and disassembled and cleaned it. I then measured the cold control pressure. It measured 1.5 BAR at 50 degrees F. This was within the range for my motor. I then started the car and it continued running.
Not well, but I have narrowed that down to a vacuum leak. New hose comes in tomorrow.
Good luck.
Old 11-16-2014, 03:29 PM
+1 on the metering plate free travel checking... sometimes it gets gummed up creating those symptoms.
Old 11-17-2014, 01:15 PM
brooklyn ny 11234
930 slant nose's Avatar
you want to sell the headache ill buy it
Old 11-17-2014, 01:31 PM
If you are serious I will sell it.
Old 11-17-2014, 07:02 PM
T77911S's Avatar
pushing down on the sensor plate adds more fuel to richen the mixture. if the cold CP is too hi doing this will help to show that if you dont have gauges.
the inlet screen to the WUR can get dirty and clogged raising the control pressure.
could also be an air leak, which leans it out and once again pushing down on the sensor plate will help keep it running.
i know it was said, but out of gas WILL do the same thing. you would not be the first to troubleshoot a non running car that is out of gas.....and looking in the tank can be deceiving.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-18-2014, 03:25 AM
brooklyn ny 11234
pm sent
Old 11-18-2014, 12:41 PM
