Rocket Scientist
964 and 964 C2 Turbo Cam Specs
It seems like a few people are running them, but the 964 turbo cam lifts are a mystery. Does anyone have accurate knowledge of the lift on the 964 Turbo cams? I suspect that it is not very high, considering that it was still a KE-Jetronic engine.
Old 11-16-2014, 08:55 PM
Metal Guru
911nut's Avatar
Thought I saw the 3.6 turbo cam specs in Anderson's book. You could check there.
My impression was it was more like the 964 cams than the 3.3 cams; more lift and a small amount of overlap.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 11-17-2014, 05:04 AM
totle's Avatar
My impression was that for the 964 turbo (3.3) it had quite the same spec as 930. just an upgradet intercooler and CIS
Specifications - 3.3 litre Turbo engine
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 11-17-2014, 05:32 AM
Rocket Scientist
He has the timing in there, but not the lift. I also have found a few errors. For instance, he lists the exhaust ports as 36 for the 3.0L 930's, and 34 for the 3.3L 930's. in fact, they are both 36mm exhaust ports.
Old 11-17-2014, 09:36 AM
Rocket Scientist
I think you are right on that. I was looking for the 3.6L 964 C2 turbo.
Old 11-17-2014, 09:37 AM
Crotchety Old Bastard
RarlyL8's Avatar
The extra power in the 3.3L C2T came from the intercooler, K27, and 0.9bar boost. Cams remained unchanged. The 3.6L C2T had more changes. I want to say they used SC special wishes grind but will have to look it up to verify. They did not use the same cams as the N/A 964 of the same period.
Old 11-17-2014, 10:55 AM
