Innocent Bystander
935 Type Boost Gauge Rebuild
Has anyone disassembled their boost gauge and refurbished it? The reset clutch on my tell-tale needle is very loose and the plastic gauge face is scratched. I'm considering replacing the face with glass and tightening up the clutch. Any experience with any of this to share? I guess the first step is to remove the bezel to access the internals. Is there a "least-damage" method to do this? For anyone who has had a gauge rebuilt by a vendor, were they able to remove the bezel and re-install it with no sign of damage? Thanks for any insight. Doug
Old 11-20-2014, 04:50 PM
Innocent Bystander
Here's a photo of the suspect.
Old 11-20-2014, 04:54 PM
xbmwguy's Avatar
north hollywood speedometer does a great job
Old 11-21-2014, 04:25 AM
E-85 sippin drunk
turbobrat930's Avatar
Yep, NHS is THE place to go for anything VDO related!!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 11-21-2014, 04:45 AM
Innocent Bystander
I usually like to do all my own work but this is one case where I may need to rely on someone else. I'll call NHS and talk to them about it. Thanks!
Old 11-21-2014, 06:11 AM
Large Member
krasuskyp's Avatar
I removed my speedo bezel (shutup, Ronnie) to replace my odo gear w/o any sign of intrusion
my VDO tell-tale was in the exact same shape, and now my NHS version has THE most Chinese water torturest annoyingest 'jingle' at off-throttle / slight maintenance throttle... arrrghhh it's annoying - anyone ever fix THAT???
I'd give the boost gauge a DIY try before farming it off to NHS, but that's just me 8-)
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 11-21-2014, 06:21 AM
I've had mine apart to replace the black ring bezel because it was bent from a previous owner or mechanic.
To make the "jingle" that sounds like a trunk monkey with a tambourine you take the vacuum/boost hose and tie a knot in it. Get a longer hose it's not long enought
Seriously, thats how you do it.
Not too tight a knot, just snug enough to dampen the minute air flow going through the hose to operate the gauge.
I have some pictures of the inside of my gauge somewhere.. I'll post them if I find them.
Old 11-21-2014, 06:34 AM
Large Member
krasuskyp's Avatar
^nowai?
THANKS JIMBO! If that works, damn man... that's HUGE!
It's soooooooooooooo annoyyyyyyyyyyyyyying. Trunk Moneky heh heh... classic.
past:
Old 11-21-2014, 06:39 AM
Pics of the insides of it. Mine works great. The clutch is adjustable but I never had to adjust it.
The clutch looks kinda like brass wavy washers in there under light compresion. The green stuff looks like glue to keep the tension adjustment on them from coming loose.
Old 11-21-2014, 06:45 AM
Originally Posted by krasuskyp View Post
^nowai?
Worked for mine.. no more gauge jingle. I forgot where I got that tip.. it was from a phone call to NHS or someone posted it and I tried it.
Now there's no more tambourine in the trunk.
Those trunk monkey videos on you tube are hilarious!
Old 11-21-2014, 07:10 AM
Large Member
krasuskyp's Avatar
UDAMAN - as usual - Jim... thanks
past:
Old 11-21-2014, 07:14 AM
Innocent Bystander
krasuskyp, mind telling me how you got your bezel off and back on without damaging it?
Old 11-21-2014, 10:54 AM
Large Member
krasuskyp's Avatar
dunno, really - it's kinda like a bra strap... you just twang it and it flies off!
kidding aside, I just used a really small flathead if I recall and OH SO CAREFULLY pried under the edge
Sorry, it was many years ago not long after I'd gotten my POS so I don't exactly recall - however - I'm no technowiz by ANY means... and... it was easy, even for ME
soooooo...
good luck 8-)
past:
Old 11-21-2014, 11:37 AM
Yup, short stiff knife blade or something similar and pry the folded over edge up a little more than half way around and wiggle it off. You can reuse the one you removed or buy a new one from NHS and fold the edge over to put it back on.
To fold that edge over on a new or reused bezel I put the gauge face down on a towel and while holding there with one hand I used a 930 wheel spacer and pushing down hard on it while rolling it along that edge with my other hand it rolled and folded the edge down like a factory job.
Old 11-21-2014, 12:24 PM
Innocent Bystander
So really, I'd be better off buying a replacement bezel and installing it instead of trying to re-use the one I take off. I suspected that was the case. I'll call NHS and see about getting a new one.
Another thing, my lens is plastic. Is that typical. I thought I'd replace it with glass. I'm assuming the other gauge lenses are glass but now that I think of it, I don't recall ever checking.
Old 11-21-2014, 01:05 PM
Just use Meguiars PlastX and polish the lens while it is apart.
Bryan O.
77 930
88 Carrera cab
14 535i M Sport
Old 11-21-2014, 01:11 PM
I've done this to other gauges in 912's and other cars and if you're careful you don't have to replace the bezel.
When the gauge is installed the back of the bezel is pushed up against the soft rubber insert in the dash so if it's a little buggered up you don't even see it.
I replaced some of mine because the person that installed the white gauge overlays in my car before I bought it bent some of the bezals.
They all ad some scratches and surface rust and needed repainting so I bought the shiny aluminum rennline bezel overlays and sanded them with 400 grit paper and spray painted them satin black enamel before installing them with black silicone glue.
The gauges in our cars come with glass in them and you can buy those from NHS too.
The VDO/NHS mechanical boost gauge has a plastic lens.. probably because there's a hole drilled in the middle for the telltale reset key. I'm sure you can buy a new one of those or try wet sanding and polishing any scratches out while it's removed.
Old 11-21-2014, 01:23 PM
Innocent Bystander
I'd rather have a glass lens. My objective is to replace the plastic lens with a glass one and tighten up the tell-tale needle clutch. The large scratch you see in the picture of my gauge is actually a crack. And since these things are so pricey, I'd prefer to have it look as original as possible once I'm done. I think I'll look into buying a replacement bezel because I know I'll screw this one up trying to get it off. I think I can roll the edge back down easily to re-install a new one. Like everything else with this car, this simple task is turning into a big project. I guess that's why I love my 930 so much. I'm never bored for lack of a project... I appreciate all the information and advice. I'll post some pictures as I get into this.
Old 11-21-2014, 01:43 PM
Banned
I removed my speedo . . . (shutup, Ronnie) . . .
Paul removed his speedo and put it on this Ken Doll - notice it fit perfectly!
Old 11-21-2014, 05:49 PM
