mussberger's Avatar
Originally Posted by Hot Euro View Post
What am I missing? The nozzles and spider are there. I am sure a prospective buyer would want to know what is missing.
The pump drive assembly off the back of the cams, several hoses, hose clamps,solenoid switch.
The tensioning bracket is there. Kinda hidden
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC.
Old 12-08-2014, 03:55 AM
Old car guy.....
Hot Euro's Avatar
I guess if someone needed it I could try to pull the pump drive assembly off the back of the cams (is that even possible?). I have never really looked back there, or seen one for sale. I guess this one didn't have the solenoid. All available hoses, clamps and hardware are there (vacuum lines not shown).
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 12-08-2014, 04:17 AM
There is a cogged drive pulley on the end of the cam.. maybe you can buy those somewhere and there's a pierburg vacuum change over valve that operates the two diverter valves.
You'll find the same changeover valves on old Mercedes in junk yards or you can buy them new for around 40 bucks. Google will find them.
0015407097
Pierburg OEM - Vacuum Valve; 3-Way Switchover Valve with 3 Vacuum and 2 Electrical Connections
Cross Reference Number : 0015408697
Multiple use relay for EGR, fast idle, transmission control, shift-point, starting booster, manifold pressure compensator, air pump, etc.
Old 12-08-2014, 05:52 AM
Rocket Scientist
Those are only on the later 1986 to 1989 930s. The earlier ones used a vacumn and boost controlled "pressure control valve".
Old 12-08-2014, 06:50 AM
mussberger's Avatar
I wouldn't worry about having everything for a buyer. You have enough there to make a real dent in someone's search. You can check prices at "DC" or someone like that and go from there.
Old 12-08-2014, 07:07 AM
