CFD CFD is offline
Identification help needed fellas...'76 930
Can anyone tell me what these two "connections" are for?
Inside the car behind left seat (passenger seat over here, drivers seat over there):
Underneath the car:
'76 911 Turbo
Old 12-05-2014, 12:42 PM
Tinkering Pays!!
mooney265's Avatar
Looks Non-Factory to me. Prob a previous owner using them [2-holes] to fish wires. Obviously, they have been cut off under the car, right?
You'll have to track where they go in the inside. Prob work their way to the front under via the center of the car [shifter tunnel]. and, remove them...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 12-05-2014, 02:44 PM
Was the car ever equipped with an adjustable boost controller?
Old 12-05-2014, 02:45 PM
CFD CFD is offline
Not that I am aware....previous owner never mentioned it. No evidence anywhere else to suggest anything like that fitted.....
Does look non factory from inside alright....yes, cut off under the car.
'76 911 Turbo
Old 12-05-2014, 03:09 PM
IMR-Merlin's Avatar
Aux heat?
Old 12-05-2014, 03:33 PM
I'll have a look at mine.................
Old 12-05-2014, 03:53 PM
Nothing at all like that in my car?
I think my car had every option in 76?
Old 12-05-2014, 05:02 PM
CFD CFD is offline
Thanks Luke...I will trace the wires into the car and see where they go, but certainly from the inside they look non standard....more like plumbing fittings!
IMR-Merlin......you mean for an engine bay blower? Unlikely perhaps as the auto heat was removed and heating back dated to manual at some point in the cars previous life....
'76 911 Turbo
Old 12-06-2014, 08:54 AM
IMR-Merlin's Avatar
No, like a gas auxiliary heater. I had one in my 930 under the left front seat. It also had a vintage 12 hour time in the glove box. You would set the time for up to 12 hours in advance and when the timer went off, it would fire up a GASOLINE heater to get the car interior up to temp. The heater was removed from my car before I owned it, but the timer and the holes under the seat were still there.
Old 12-06-2014, 09:24 AM
CFD CFD is offline
Ah, interesting, yes, heard of those alright. I will do some tracing on the wires anyway and see what comes of it. Thanks...
'76 911 Turbo
Old 12-06-2014, 10:31 AM
aka 'vageen'
unclebilly's Avatar
That's my guess.
Old 12-06-2014, 12:54 PM
Close enough to the pump to suggest something to do with fuel?
Old 12-06-2014, 12:56 PM
dies ist Standheizungen
Old 12-06-2014, 01:04 PM
CFD CFD is offline
For a heater you reckon?
Here is a better pic showing the tubes - the one that isn't cut follows along the tunnel and goes up under the dash. Need to drop the AC vents bolted on under the dash to track it to its end. Just had an ankle operation so have to wait a few weeks before I am up to crawling about in the footwells to find the end.
I don't see any sign on the dash/engine bay of an adjustable boost controller....but who knows what could have been done I suppose...is this the kind of plumbing that is used for a boost controller?
'76 911 Turbo
Old 12-07-2014, 06:32 AM
IMR-Merlin's Avatar
I'm still going with a gasoline heater.
Old 12-07-2014, 06:56 AM
aka 'vageen'
unclebilly's Avatar
Boost controller has a vaccum bleed line to the knob under the dash and a switch to over ride the fuel cut off.
You have lines and a wire... That's what you need. The lines would have gone to your wastegate.
76 930 - featured in Sept 2013 Pano
Yoosta have: 90 C4 Targa, 87 944, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche
Old 12-07-2014, 07:54 AM
Looks just like my ex dial a death.
63 356 So Called Outlaw
76 930
Old 12-07-2014, 08:10 AM
Not sure 76 had a fuel cut off for over boost?
I'm going with gasoline parking heater given your climate.
Old 12-07-2014, 11:50 AM
Maltese Falcon's Avatar
Google
Eberspacher Gas Heater
There is another brand as well, can't think of it at the moment.
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 12-07-2014, 10:35 PM
Banned
According to the Porsche PET for 76-77 Turbos, they did come with an overboost switch (cuts the fuel pump circuit ground at a certain bar - around 1.2bar for 3.3l engines but don't know for 3l models).
Page 35, item #24 is the overboost switch -
http://www.porsche.com/all/media/pdf/originalparts/en/E_911T_KATALOG.pdf
Old 12-07-2014, 11:12 PM
