LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
930 rear camber adjustment problem
My driver side rear wheel is about 1/2" tilted in (negative camber). I have attempted to adjust it via the camber adjustment bolt. I loosen the 19mm locking bolts to the Torsion arm and also the toe in and camber nuts. I adjusted the camber eccentric bolt to its most positive point and I cannot get the negative camber out. I am looking for 0' camber to match my passenger side. What I am I missing?
Old 12-06-2014, 03:00 PM
Non User
infraredcalvin's Avatar
Looks like you're running close to euro height, doesn't look like its sagging on one side either, but you may want to check for a broken torsion bar. I typ try for about a 1/2 deg neg camber on the rears.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 12-06-2014, 05:52 PM
That's a good suggestion, as when I was adjusting the ride height it didn't seem as though there was much tension on the spring plate. Thanks for the reply.
Old 12-07-2014, 08:38 AM
Tags
930 , alignment eccentric , camber
