Hydraulic clutch
A customer of mine is in the process of building a RCR 917 Lemans Porsche replica. It has a Porsche flat 6 engine with a 930 Turbo Porsche transmission which has been "flipped".
They have requested a hydraulic clutch conversion. I thought that given the amount of uses the Porsche transmissions have, there may already be something on the market, or someone else may already know of the components required. Or maybe even a later model Porsche unit might be able to retro fitted, if they are hydraulically actuated, rather than a cable.
Unfortunately I'm not to familiar with Porsches.
Any suggestions?
Old 12-14-2014, 08:28 PM
G50
Old 12-15-2014, 03:19 PM
IMR-Merlin's Avatar
G50 trans uses a hydraulic clutch.
Old 12-15-2014, 03:28 PM
Tug68's Avatar
I can put you in touch with someone that has a G50/50 with the shortend bell housing if you need.
Old 12-15-2014, 03:40 PM
Welcome to Windrush Evolutions - WEVO - Porsche Products
1987 GP White 930
1977 Ford Bronco
Old 12-15-2014, 03:49 PM
Thankyou gentleman.
I shall follow up that link
Old 12-15-2014, 09:48 PM
TurboKraft's Avatar
This is done all the time in the off-road and kit car markets. The 915 transaxle is commonly used, the "little brother" to the 930 4-speed. A "pull" slave cylinder is used, and there are lots of options available.
Google search "hydraulic pull slave cylinder" will get you everything you need -- cylinders from Wilwood, CNC, Speedway, etc.
General write up:
How to Set up a Hydraulic Clutch
Making a bracket to mount off the gearbox will be easy.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-16-2014, 09:34 AM
VZ935's Avatar
Send a message via AIM to VZ935
I put a flipped short bellhousing box in my car
A bunch of old race cars
Old 12-19-2014, 09:59 PM
Das Schnell Ei's Avatar
Is anyone here running that Wevo twin disc setup?
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 12-20-2014, 08:30 AM
