johnman001's Avatar
BOV Clicking/Clunking Sound
How loud is a stock BOV clicking sound when the seals inevitably deteriorate?
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car...........| 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - Unit Body (TBD)
1971 914 (TBD).....................|
Old 12-23-2014, 08:18 AM
Crotchety Old Bastard
RarlyL8's Avatar
Stab the throttle at idle and you will hear it very easily.
Old 12-23-2014, 09:28 AM
Tinkering Pays!!
mooney265's Avatar
sounds like a hammer tapping on your intake manifold. typically come in when you tap the throttle as the throttle descends. One tap each cycle of throttle.
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 12-23-2014, 09:49 AM
johnman001's Avatar
Do they ever rattle at idle? Or is it only one time when vacuum goes high?
I replaced an engine that I could find nothing wrong with other than it did make some knocking noises when the throttle was blipped. I had thought it was a chain tensioner (which I replaced), and then concluded it was a rod knock and replaced the engine rather than rebuild (back when a running engine was cheaper than rebuilding). The engine still sits as it was removed. I am now thinking (15 years later) that my less than professional opinion could have been wrong. I am considering opening up the BOV/pop-off housing to see if the seals are indeed deteriorated. At some point, I will rebuild this engine and will find out definitively, if my original conclusions were correct (rod knock).
My current condition (in a different thread) is a distinct vacuum leak, but I haven't heard the current BOV with a leaking seal make any noises.
Now that I have read a bunch more on the stock BOV, it got my curiosity going. One of these days, I will have to take that engine apart, find out what the noise was and rebuild it.
John Flesburg
Old 12-23-2014, 03:31 PM
RarlyL8's Avatar
A rod knock will sound with each rotation of the engine, a BOV click will only sound when blipping the throttle. After sitting 15 years the wax gaskets will now be deteriorated so not a definitive test. They will crumble when you take off the end caps.
Old 12-23-2014, 07:04 PM
