Chain fence eating turbo
Quote de Tippy
I agree with everyone; air is a fluid and is affected by intake runner length, shape, radii, etc., creating variances in flow.
fluids don't compress...gases do.
Liquids you meant
Old 12-30-2014, 04:41 AM
IMR-Merlin's Avatar
Fluids and liquids will compress to some extent. Try using water for brake fluid.
Quote
Quote de Tippy
Liquids you meant
Old 12-30-2014, 06:38 AM
3 restos WIP = psycho
kenikh's Avatar
OK, fine, absolutes are never absolute. But liquids only compress nominally. Water would work fine as brake fluid if it wasn't corrosive and didn't turn into a gas at the first breath of heat. I'd suggest you get more sponginess from mechanical give (master cylinder, lines) than from fluid compression.
But the main point being made is that gases tend to follow the laws of fluid dynamics.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-30-2014, 07:30 AM
lite75's Avatar
Always the path of least resistance.
75 930, 76 930, 83 SC EFI turbo
Old 12-30-2014, 08:19 AM
Das Schnell Ei's Avatar
Originally Posted by unclebilly View Post
It matters far less with forced induction.
I would say it matters more if you can burn a piston after one or two lean pulls...
even when all of the runners are the same, the location of the TB relative to the intake ports effects air distribution... there are a lot of things that matter
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 12-30-2014, 08:31 AM
Large Member
krasuskyp's Avatar
Hey now!
Don't go givin Robbby any ideas here....
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 12-30-2014, 09:16 AM
