-   -   PLS HELP!! WTB - '79 930 York A/C Compressor (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/845165-pls-help-wtb-79-930-york-c-compressor.html)
Pharris409 01-03-2015 01:01 PM
I'm probably one of many looking for a '79 930 York A/C Compressor.
I've tried all dismantlers, Pelican, Google search, eBay etc and have never seen one listed for sale. I have a fully original '79 930 except for the *%#! A/C Compressor and would love to score one to finish off my car.
Any help, ideas or better yet an actual A/C Compressor would be appreciated. I'll pay top dollar. I'm sure they are out there in someone's garage boxed up with other old parts, I just need to locate that needle. :confused:
Thanks again for any help!http://forums.pelicanparts.com/uploa...1420317876.jpg
http://forums.pelicanparts.com/uploa...1420318768.jpg
http://forums.pelicanparts.com/uploa...1420318791.jpg
kenikh 01-03-2015 04:55 PM
I just bought one for $50 last month. They're out there. Remember, they are identical to the ones installed in an SC.
kenikh 01-03-2015 04:57 PM
BTW, your head light washers appear to need attending to. ��
Tom F2 01-03-2015 07:29 PM
I don't think so. Turbo 3.0s used the same compressor as SCs, but early 3.3s used a York with a different valve and cylinder arrangement and maybe other differences.
kenikh 01-03-2015 07:33 PM
Interesting. Had heard the opposite. Would love to know the differences.
Ronnie's.930 01-03-2015 11:19 PM
Pharris, I'm curious as to why you want to put one of those turd Yorks back into service?
Tom F2 01-04-2015 05:53 AM
I believe that all of the factory A/C from roughly 1970 through 1983, except Turbo 3.3 cars, used the York 210 heavy duty compressor, an aluminum, twin cylinder, 10 c.i. displacement unit. The Turbo 3.3 used a York 209 super-compact mini unit, with rear mounted fittings. The 209 mini is also aluminum, with 9 c.i. displacement unit and smaller outside dimensions than a standard 209. All of these units are good for 6000 rpm. You should find a nameplate on the compressor, identifying the model and date of manufacture.
As far as I can tell, there are differences between the two compressors - including the clutch and sheave - but many parts will interchange.
I think that earlier 911s used York compressors, too, but I am not sure of the model.
York compressors were used in many auto a/c systems, including Volvo and Mercedes, so parts and used units should be easy to come by. I don't know what other cars, besides the Turbo 3.3, used the 209 mini, and the rear fittings may be hard to find.
You should be able to find a York service manual on line, which will help to sort this out and to repair your unit if need be.
Pharris409 01-04-2015 09:06 AM
Kenikh - looking into the headlight washers per your comment I found a reference to somewhere around VIN 817 they switched from snorkel to flush headlight washers. That would mean you are correct and I should have snorkel. I'm assuming those are about as hard to find as the York Compressors. I did see a post for a website in Germany that supplies aftermarket snorkel washers, not sure quality but they appear to be a great match aesthetically. Comes as a set with all parts including washers.
Pharris409 01-04-2015 09:24 AM
Ronnie - fair question and not the first time I've heard the word "turd" used to describe the York compressor. I definitely DON'T want one to stay cool in the summer time, originality is the only reason. Purchased the car several months back and it is so close to being fully stock that I'm wanting to complete it. Not to say I'm not constantly thinking of all the cool modifications I could/should make to it.
One thing I've learned is that there is a lot of confusion surrounding the 'correct' compressor on a '79 930. Every dismantled I call says they have plenty available. When I ask for a pic prior to purchase they get all defensive and quote me how many years they have been Porsche experts. It always ends the same; they don't have one and they 'forgot' the '79 used a different compressor.
I think the reason they are so hard to come by is that they truly were turds and have been flushed long ago.
Anyway, I would still like to find one and if anyone has any ideas or comes across one please let me know.
Thx
Ronnie's.930 01-04-2015 09:40 AM
Pharris, understood. I don't think in terms of originality with these cars, but was wondering if that was your motivation for a York.
Just for the sake of bullshatting, the York compressor gets its turd distinction primarily because it is heavy, vibrates a lot (compared to a rotary compressor, etc.) and requires a lot of energy to operate (I would have to look up the stats, but I know it uses more than double the horsepower of a rotary version). I think it performs OK in terms of compressing the refrigerant.
One guy you might check with about buying a York is Charlie Griffith. I know that he has replaced many of these over the years and might have some on hand. He is also very friendly and helpful.
Griffiths - Porsche Air Conditioning + Engine Components
Maltese Falcon 01-04-2015 01:36 PM
Try;
Scott's Independent Porsche, in Anaheim Ca.
He might still have his stash of York compressors...maybe even my '79 !
Marty
Pharris409 01-04-2015 02:29 PM
Thanks Marty! I'll try him first thing tomorrow.
turbo nut 01-04-2015 04:36 PM
Is this what your looking for?http://forums.pelicanparts.com/uploa...1420418164.jpg
Pharris409 01-04-2015 06:32 PM
Can't tell from that angle, can you take another and get the entire compressor in the picture? The mfg date looks promising. Thanks
turbo nut 01-04-2015 07:25 PM
Hope this helps and is the correct one you need.http://forums.pelicanparts.com/uploa...1420428257.jpg
http://forums.pelicanparts.com/uploa...1420428276.jpg
http://forums.pelicanparts.com/uploa...1420428295.jpg
http://forums.pelicanparts.com/uploa...1420428314.jpg
Pharris409 01-04-2015 10:18 PM
Turbo Nut, this appears to be just what I was looking for! I just sent you a PM.
kenikh 01-04-2015 10:22 PM
Good pics. thanks!
wildturkey 01-05-2015 12:15 AM
They are out there. I just picked up a 75 York for $200.
If only the guy could get the bracket to me.................
Shaun @ Tru6 01-05-2015 04:15 AM
Hey Patrick, yes, it looks like this is the one you need. Here are pics of Larry's 79 with original AC. I had two more bites but they turned out to be regular SC units as usual.
http://forums.pelicanparts.com/uploa...1414720908.jpg
http://forums.pelicanparts.com/uploa...1414720922.jpg
Pharris409 01-05-2015 01:49 PM
Thanks everyone, got one. Feel lucky to have found one.
Thanks Turbo Nut!
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
