-   -   Intake Port Size Affects - CIS (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/846843-intake-port-size-affects-cis.html)
RarlyL8 01-24-2015 04:57 PM
Good question, I also don't know the limits of the air meter plate. It seems to handle 400WHP just fine but 500WHP is now 2x the power it was originally designed for.
WERK I 01-25-2015 04:40 AM
copbait was referring to the throttle body diameter.
IMHO, throttle body has little effect as long as the intake tract isn't compromised by it. In the case of the 930, I doubt it is. I think people may go to another throttle body, but only because the abundance of intake of intake signals in newer designs.
On this subject of port design, I worry about atomization of fuel due to a change of port diameter at or near the injector. A loss of air velocity at or preceding the injector will cause a loss of velocity and atomization (reverse-venturi effect).
Dirk, have you seen cases where the CIS manifold is ported to a larger size only to find there's loss in performance?
Brian,
Personally, I think the 3.2 head is a very good starting point. They are probably the best flowing factory heads leading up to the 3.6.
Edelweiss 01-25-2015 06:01 AM
CIS plenum
Brian,
Yes we have seen this - a good example is the first generation Golf GTI 16 V and the two generations of plenum. There even was a part from VW Notorsport which was significant bigger in diameter.
Today we know the smallest one was the best one, making the most power with the best torque and the nicest curves.
In the further development of this engine later used as stw and kit car engine the 2,0 l race heads are manufactured with smaller ports then the first 1,8 l street heads called kr.
These engines are making 300 plus HP with smaller ports then the 129 HP street engines !
And if you remember a 1,6 l first generation GTI engine making 200 plus HP with 40,5 mm inlet valve and 35 mm exhaust valve you have to see the very small ports to realise when a port really gets too small.
Please hold in mind that we can take as a fact:
The way from air filter to the inlet valve is always working as its smallest spot.
Also I prefer to start with small ports since shape rules diameter !
There is nothing better then a set of turbo heads with a good porting.
These heads have a good amount of meat for someone who knows how to make them work.
The most important place to work on is around the valve seat, port bowl and port flor.
All na porsche cams are a compromise, if it is SC or 964 - you can do much better with a dedicated turbo cam - say this because the port / valve must me triggered by a good lobe to make it work.
A relatively bigger port can be useful but it is more sensitive in shape - a smaller port needs less know how to make it work, same with valve size.
The bigger you go the more you have to know what to do - this is the reason why we very often see ports destroyed making less power then beeing standard.
So under the line: no need for new heads - use the turbo set you have and find someone who knows how to do a good valve seat with a corresponding port.
Best reg.
Dirk
totle 01-25-2015 02:48 PM
Interresting reading :D
Edelweiss 01-26-2015 06:51 AM
Metering plate
Since a question comes up - the metering plate is not the limit, we have seen 720 HP already and there is still room to grow...
Here are some porting pictures - we have done these heads recently:http://forums.pelicanparts.com/uploa...1422287289.jpg
http://forums.pelicanparts.com/uploa...1422287328.jpg
http://forums.pelicanparts.com/uploa...1422287352.jpg
http://forums.pelicanparts.com/uploa...1422287372.jpg
http://forums.pelicanparts.com/uploa...1422287401.jpg
http://forums.pelicanparts.com/uploa...1422287421.jpg
http://forums.pelicanparts.com/uploa...1422287443.jpg
quattrorunner 01-26-2015 07:19 AM
Wow very nice.
So you're saying the limitations are the port? Not size either but smoothness?
Edelweiss 01-28-2015 07:17 AM
Shapeshifter
Originally Posted by quattrorunner (Post 8456375)
Wow very nice.
It is all about the shape.
To achieve what we all are looking for you have to modifie it with a strategy behind what you do.
First analyze the port and understand the concept of the layout.
In the next step you promote the strength and fight the weakness.
The Porsche ports are quite simple and they just follow the reality that its a flat six boxer with the inlet on top and an upright carb in the beginning.
There is no great finesse in it and the development was even going backwards from 964 to 993.
So starting with a small beefy port there is a lot to improve.
I always start with the smallest base port I can possibly get.
Best reg
Dirk
quattrorunner 01-28-2015 07:29 AM
This excites me for the next rebuild.
JFairman 01-28-2015 07:59 AM
You want to reshape the port to lift the airflow towards the high side of the port so less of the air fuel mixture is flowing over the short side radius. That way the air flow has more room to straighten out before it hits the backside of the open intake valve.
That improves and maximizes flow.
Don't take material away from the short side radius or else the airflow will drop lower in the port and will be hitting the backside of the intake valve at an angle and that's not good. It will create bad turbulance that makes the port flow worse than stock.
Just smooth the short side radius a little if it needs it and that can be carefully done by hand.
If anything you add some aluminum to the short side radius by tig welding it in and then carefully and evenly smooth it out by hand or with CNC port milling machinery.
Surface turbulence grooves machined into the port walls like the ones in the pictures above make the air fuel mixture laminar flow tumble along the surface and that keeps the port walls from wetting out with fuel and helps to keep the air fuel mixture atomized.
The best place to have hand done or CNC head porting work done in the USA is: Xtreme Cylinder Heads And Castings in Palm City Florida.
Watch a cool video of it being done here:
https://www.youtube.com/watch?feature=player_detailpage&v=DyvXsgIPlPU
They're a 45 minute drive north for me so I've been there and the owner Bill is a really good guy.
quattrorunner 01-28-2015 08:14 AM
Wow
RarlyL8 01-28-2015 11:30 AM
... but you better be sitting down when they tell you the price. I'm doing my own.
kenikh 01-28-2015 11:50 AM
Yes indeed. I had Steve Weiner do a set of 69S heads for me, too. Porting and heads were $5K, soup to nuts, IIRC. We designed the entire intake tract as a tapered bore venturi, from air horns at the top of the MFI stacks, through the stacks, through the TBs, from the edge of the port, through the valve seat. 2.25L, naturally aspirated 911 motor made 240HP at 7300 RPM. Made power to 7800. The torque curve was silly far down low, too. I never quote port diameter on that motor. The size of the port was immaterial, as it was just a cross section at an arbitrary point in a larger system.
A diligently designed intake system is time consuming, costly and pays amazing dividends.
JFairman 01-28-2015 01:48 PM
I've seen pictures of ports Steve Weiner has posted and they were the exact same pics that are on xtreme cylinder heads website.
I've talked to Bill and mentioned that and he said Steve is a customer that sends them to him.
So.. you can skip the middle man and send them directly to xtreme heads and the final cost will be much less.
kenikh 01-28-2015 02:07 PM
That's news to me - Dick Evelrude used to do his port work. Dick and Steve had a nice business relationship, in that Steve would manage the projects and Dick would get a steady stream of work - and not have to deal with clients. I also know from previous conversations that Dick and Steve spent a LOT of time on the flow bench and in the dyno room coming up with those port profiles.
Admittedly, Dick has been on the verge of retirement since I was knee high to grasshopper, so maybe he finally decided to hang it up. Or maybe Extreme's capability and port geometry is just that much better...hard to know without asking.
I'll call Steve to catch up and see what the latest scoop is. Just for fun, my old heads...don't look like Extreme heads:
http://i25.photobucket.com/albums/c7...n/IMG_0487.jpg
http://i25.photobucket.com/albums/c7...n/IMG_0493.jpg
http://i25.photobucket.com/albums/c7...n/IMG_0502.jpg
http://i25.photobucket.com/albums/c7...n/IMG_0497.jpg
http://i25.photobucket.com/albums/c7...n/IMG_0498.jpg
http://i25.photobucket.com/albums/c7...n/IMG_0499.jpg
http://i25.photobucket.com/albums/c7...n/IMG_0500.jpg
totle 01-28-2015 02:13 PM
Interresting. That golfball effect in the port looks nice.
Wonder how much extra effect that gives.
My 930 tops was ported by extremecylinderheads. Wish hey had this tool then :-)
911nut 01-28-2015 02:58 PM
I have to think that you can't get away with so little of the valve guides left on a turbo engine.
I once saw a solid model of ports on a NASCAR engine. The ports were increased in diameter gradual transition around the valve guides to gain back the lost volume. Looked like a snake that swallowed a tennis ball.
JFairman 01-28-2015 03:11 PM
Those look just like the CNC Rottler P69 machined ports that xtreme cylinder heads does.
Maybe someone else in the states has one of those machines too. All you need is a laptop with a well written 930 head porting program on it to run the machine and make it happen and hope the power doesn't go out while the cutting is going on.
The small oval grey areas in the intake ports looks like JB weld or Devcon marine epoxy that was put on the outside of the port area of the heads so the intake ports could be cut higher up in the heads without cutting completely through the port.
I've done that on old single cam BMW 4 and 6 cylinder water cooled heads so I could grind more material away on the top side of the port leading up to and around the intake valve guide.
When doing that I would port match the bottom and sides of the intake manifold runners to the finished intake ports but not the top side. That way a nice almost 1/4" deep anti reversion cut was created on the top side of the port where the intake manifold bolted on to the cylinder head.
Anti reversion cuts improve high rpm performance when using long duration high lift cams in normally aspirated high compression engines.
philip j 01-28-2015 04:20 PM
Here's my heads done by Xtreme. Opened up to 42mm. 52mm intake valves/42mm exhaust. Philip http://forums.pelicanparts.com/uploa...1422494441.jpg
philip j 01-28-2015 04:27 PM
another pic.http://forums.pelicanparts.com/uploa...1422494859.jpg
Tippy 01-28-2015 05:05 PM
I have to think that you can't get away with so little of the valve guides left on a turbo engine.<br>
Like a cobrahead intake duct?
klefroid 03-10-2015 03:19 PM
Here was another good thread long time ago but may be usefully to.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/455530-homebrew-head-porting-attempting-dark-art-5.html
Originally Posted by totle (Post 8460477)
Interesting. That golf ball effect in the port looks nice.
Yes golf balls have a fascinating aerodynamic.
https://www.youtube.com/watch?v=LvVuuaqCC7A
One day they shape the valves to :D
http://forums.pelicanparts.com/uploa...1426029588.jpg
Black_Hat 03-10-2015 03:40 PM
more
Surface Turbulence – Article | metricmechanic.com
klefroid 03-10-2015 03:51 PM
Ok, they do exist, best to replace them every 20 hours :D
Williams MotoWerx - Over 20 years in the industry providing performance parts for motocross.
http://www.williamsmotowerx.net/images/valve2.jpg
RarlyL8 03-10-2015 06:59 PM
Waste of effort for 1-2 HP. I'll add 1/100th bar boost. :D
Heads should be done soon, I'll post pics. Very exciting stuff!
Alan L 03-10-2015 08:17 PM
FWIW, I just opened my intakes to 38mm, and 38mm injector blocks. Installed Elgin cam - in between SC and 964. Didn't want to loose to much low end. I discussed all this with Chris before settling on parameters. He did say that going to 40mm intake still showed improvements on dyno.
I plan to test it all at track day next week, hopefully I can report some improvements.
Alan
RarlyL8 03-11-2015 04:01 AM
Please do Alan, real world data is all that matters!
We decided on 40mm intake / 37mm exhaust using anti reversion bumps along the path. Never done it exactly like that before so anxious to see how it all works out. Unfortunately that is not an isolated change so I probably won't be able to judge the merit of it in this case, it's just part of the package.
Alan L 03-19-2015 11:03 PM
Just back from my first track run after the following mods - Elgin cam (SC330 brian?), 38mm ports/injector housing, 964 IC. So more than one change, which is what you do while in there.
What I can report is a rocketship. The lag end doesn't seem to have changed, but the boost onset is probably not as vicious as previous (which I found beneficial for the track, half way round a corner with it nailed to WOT). The top end just keeps going - from mid range up. I was running out of fuel at the top end and had to short shift to keep the AFRs below 12.5. FWIW there were times in the 13s and no damage.
Short shifting, 0.8 boost, and 3 sec gain on previous lap times - and this is with a passenger in the car, and previous lap time set at 1.0bar. Once I get the tuning sorted..............
Regards
Alan
RarlyL8 03-20-2015 07:20 AM
3 second lap improvement sounds huge! Yes with those cams and head work the engine can move a lot more air.
We should be finished with the injection blocks soon and the heads will follow. Really excited to see how well it will all work together.
Alan L 03-20-2015 10:28 AM
The AFRs are climbing muuuch quicker than they used to after boost dump. This means as we go thru the mid-upper rev range the engine must be shifting muuuch more air. Previously I used to watch it steadily progress through about 0.5 AFR once the boost dump had settled. The boost dump is not noticeable now (the engine needs that fuel and gobbles it) and the numbers just shoot for the upper end within seconds. I was shifting at around 5,400 to keep it around 12.5. There is a lot of improvement in the post boost power, and I think the transition is a lot more manageable. It has improved the engine all round. (Which I think helps the track driveability - easier to get power down earlier).
Definitely a good change.
Regards
Alan
