Turbo Powered Snow Blower
I was looking at the Fifteen52 wheels for a second street set with better tire options than my 16" wheels. I dig the Gold and Black wheel. You would think they would offer the offsets in this thread with Magnus Walker backing them. But they only have 17X11 in a +17 or -8.
Derrick |
Will any other newer porsche wheels fit a 930 with adapters?
Boxsters? Cayenne? 996? 997? These wheels are plentiful, and cheap. Would make great track wheels... Curious why no one ever does that? Is it simply not possible? Do any other OEM wheels fit a 930? |
Large Member
Will-
So yer car's near done & yer about back in action (kiiiiindsorta like this "guy" Rawknees is allllll action allllll the time with a gangbang line 'o doodz - much like that other "guy" Ronnie was)? Noice! Really good to hear. I've heard good things on them Nittos. Do report back.
Paul... CT | '87 930 | '08 M3 6gang vert | past: | '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq | | '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 | |
930T Owner
- Chris.
Hams930T 2017 Turbo S |
So the tires I'm looking at (Nitto 555 G2) have 315/35/17 for rear and 245/45/17 or 255/50/17. I'm not sure which would be the better choice up front.
Kuhmo's Ecsta XS has the 315 as well along with more options up front: 235/45, 245/35/40/45, and 255/40. Rears seem to be pretty simple. The choices up front are many and I could use a hand with selection. Thoughts? Thanks! |
Mighty Meatlocker Turbo
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo ![]() ![]() |
930T Owner
You could run a 245 tire up front on the 9" wheel if you wanted but the 245/40 aspect ratio will lower the OD enough that it looks shorter than the rear setup and might look funky to you. Personally, I'd focus on 255/40 combo up front. - Chris.
930T Owner
Black on hyper Classics in 17" with the NT05 255/40 and 315/35 combo:
![]() ![]() 18" Fikse setup with 245/35 and 315/30 Michelin PS2 combo: ![]() ![]() ![]() The 245 tire looks a lot smaller compared to the 255 tire. But that's also hard to judge since one set is a 17" and the other is 18"... Chris.
Oh my,your 930 is freeeeeekin beautiful.So 17 up front 18 in back does she track good??
Sent from my SM-N910T using Tapatalk |
930T Owner
Only reason I have 245's on the Fikse's is because Michelin discontinued the 255/35/18 in the PS2. - Chris.
Chris- Thanks for the real world feedback. Your car looks great. Will |
930T Owner
Thanks for the compliment and always happy to provide help/feedback. Hope you have a blessed weekend! Chris.
Always learning something
930 (1987) Wheel help needed
Sorry to resurrect an old thread but I'm having a hard time with my just ordered new wheels.
I'm running stock ride height, stock spacers on my 1987 930. Wheels are Euromeister Fuchs replicas: 17x8 et 11 fronts NT05 235 40 17 17x9 et 15 rears NT05 275 40 17 The fronts look like they're about 3/4" sticking out past the front fenders and rub on full lock while the rears are flush but rubbing the fender under normal driving. Can this be fixed by adjusting rear ride height? Should I be looking at either new wheels or spacers? Getting very frustrated. HELP!
1987 930 Guards Red 2004 Acura NSX Supercharged 2006 Mini Cooper S 2019 Cayenne eHybrid |
930T Owner
Maybe someone else can chime in but I don't see how that low of an offset would work on a front turbo fender car. Sorry. Chris.
Thanks Chris.
Here's the sizes offered: http://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2014.cgi?SUPERCAT_FLAG=Y&make=POR&Context_make=&please_wait=N&LastVisited_input=911M&Previous_Section=&forumid=&threadid=&command=DWsearch&description=Euromeisters&I1.x=0&I1.y=0 Should I return the 17x9 and run 17x7 fronts and move my 17x8's to the back?
930T Owner
My main problem is actually the rear tires rubbing the fenders. I've managed to scrape paint off the drivers side fender as well as create a nice score line on the tire
930T Owner
Are you running the factory spacer still? Easy fix would be to run a thinner spacer to move the wheel inboard. - Chris
Thread Tools | |
Rate This Thread | |
