930 (1987) Wheel help needed
I will be in the hunt for some new Fuch repros in the coming months. I've read every thread I can find specific to 930s and wheel fitment. The topic of offsets, ET, fitment, etc are not agreeing with my brain, so I am turning to fellow owners to dumb it down for me.
My last set of wheels were BBS LMs 7.5 x 9 and running 205/50 & 255/40 Pilot Sports. To the best of my knowledge, the car has stock spacing. My car is lowered to Euro height and primarily used for street driving and tire wall smashing. I'm going for a more aggressive look but don't need the absolute max amount of beef I can stuff (go for it Paul and Ronnie) in the wells. I dig the Fuchs look and have a manufacturer in mind but I'd like some shared experience on wheel size specifically:
1. are 17" rims still optimum size for tire selection?
2. I see a lot of folks running 9x11. Do 9" fit the front "no problem" or does finessing come into play
3. anyone run a 8 x 10 set up? If so, what are the best tire sizes?
I appreciate any thoughts and thanks for helping me get my car back on the road.
Will
1987 Marine Blue 930 - White Plains, NY
Old 01-21-2015, 06:03 PM
Banned
Originally Posted by OldSpool87 View Post
. . .but don't need the absolute max amount of beef I can stuff (go for it Paul and Ronnie) in . . . .
Will
Will, you and Paul definitely have VERY different goals in mind with regard to "beef"; Paul is looking for all max all the time!!!
Last edited by Ronnie's.930; 01-21-2015 at 06:34 PM.. Reason: Word choice change before Paul had a chance to twist it!!!
Old 01-21-2015, 06:23 PM
Norm K's Avatar
Originally Posted by Ronnie's.930 View Post
Will, you and Paul definitely have VERY different goals in mind when it comes to "beef"; Paul is looking for all max all the time!!!
Just when I think I oughta feel sorry for the abuse poor Paul endures, I realize the error of my thinking ...
`66 912: Sold, `80 930: now resides in Poland, `84 Targa, now resides in The Netherlands, `75 911S: now resides in Northeast Germany, '83 Targa
Old 01-21-2015, 06:34 PM
Banned
Endurance is Paul's middle name (so I hear - no personal experience with the matter, mind you!)!
Oh, and the word "her" in that clip needs to be changed to "him" in order to accurately reflect on dear ol' Paul!
Old 01-21-2015, 06:44 PM
930T Owner
Hams930T's Avatar
9" front wheels work no problem. Tire choice is more of a concern here. If you run a 255 tire you'll likely rub the tub on the inside. If that is a big concern for you, then run a 245 series tire.
Aspect ratio is the other concern. If you run the 255/40/17 tire - you need to be careful of the OD. Specifically - you run a chance of hitting the oil cooler shield inside the passenger side front bumper. To address the front with a 9" wheel and 255 and make sure you have zero issues, you would want to: 1) roll your front fenders, 2) install rack spacers to limit your turn-in, 3) remove the aluminum bracing inside the front passenger side bumper.
So... With your setup I would recommend you go with a 9" wheel and offset +30. As for the tire, if you want to keep it "safe" then I would go for a 245/40/17. If you want a little more "beef" in there- go for the 255/40/17.
As for the rear... 11" is really not wide for the turbo body. Given that your car is lowered, you could easily run a 11" wheel with +0 ET. In fact, you can really run down to a -5 ET without any issue. Tire size obviously would be a 315/35/17 paired with the 11" wheel. You could technically run a 11.5 +0 ET with a 315 on your height no problem though.
So, for safe setup - I would recommend:
17x9.0 +30 ET with a 245/40/17
17x11.0 +0 ET with a 315/35/17
Aggressive setup:
17x9.0 +30 ET with a 255/40/17
17x11.0 -5 ET with a 315/35/17
Hope this helps you out. I've tried numerous setups on my 930 and I have four sets of wheels covering all the fitments I've noted above.
Kind regards,
Chris
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 01-21-2015, 08:37 PM
930T Owner
Hams930T's Avatar
Also curious... What are you going to do with your LM's? If you're going to sell them I'd love to pick them up.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 01-21-2015, 08:39 PM
Ronnie- we all have our beefs.…
Norm- classic clip!
Chris- I appreciate the "real world" feedback. Send me a PM with your email or phone number and we can chat about the LMs. There are a few details you should know starting with there are three (not 4) wheels.
So, based on Chris's feedback, an awesome movie clip and Ronnie's dig on Paul, it looks like 9x11 with attention to tire size is a good route. Any reason not to run 8 x10s?
Thanks for the responses and laughs.
Old 01-22-2015, 05:34 AM
911tracker85's Avatar
I got 3 pairs of 16" BBS wheels with my 930 clone project.
really wanted to use them when I finish the build, but it just seems there are no good street-able options for wide 16". I know one set is 11" wide, and had 315 on them. the other two sets have good but old michellins 225 & 265, not sure of exact widths. they will need to be refinished.
may put them up for sale in case some racer may be able to use with track tires.
only option I found was Mickey Thompson, but have been told they are not good tires for my beast.
car was built with modified 3.3 turbo and steel wide body, but left the stock SC suspension and brakes. planning to put on a 930 brake kit and consider 15" wheels, and upgrade the suspension. I have heard you can still get some wide tires in that size, but need to research further.
pic of PO.
closeup of one wheel showing numbers.
Bob Cox
84 928S, Ruby Red linen/brown interior - preferred DD
85 911 Targa, White Gold/brown int - retired from track.
86 944 turbo my new DE/track car.
78 930 clone project car.
Old 01-22-2015, 06:21 AM
Das Schnell Ei's Avatar
I like those wheels....
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 01-22-2015, 07:31 AM
930T Owner
Hams930T's Avatar
Norm- classic clip!
Hey bud,
You could run the 8's and 10's combo; but your car is a widebody car. I would say really its just a matter of taste for you. The 9's and 11's combo gives you pretty good options for tires in the 17" range. You could run a 245 tire front and the rear you certainly have a choice between a 295 and a 315.
My personal feeling - if you're going to spend good money on a set of custom built Fuchs in the 17" look - get something that makes a statement. the 11" rears have a 4" lip which looks killer, and the beefy tire under the rear body work just really looks at home.
I don't think you can go wrong with either look.
Chris.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 01-22-2015, 07:45 AM
I definitely like the dish on the rear wheels. Good points…all taken. Thanks!
Old 01-22-2015, 02:37 PM
930T Owner
Hams930T's Avatar
There you go buddy!
My 17x11.5's have a 4.5" lip. It looks killer.
Chris.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 01-22-2015, 02:42 PM
needs new tires. Again.
fraggle's Avatar
Nice discussion here and good reference. Numbers. Thanks guys. No gotchas for the same setup on an 85 Euro 930?
'87 928S4 5spd - Owner
'85 930 EURO - Caretaker
Old 01-22-2015, 05:08 PM
930T Owner
Hams930T's Avatar
No gotchas. Fitment specs would be identical.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 01-22-2015, 05:49 PM
Large Member
krasuskyp's Avatar
Hey Will-
Good to see you inquiring on this - means yer car's coming along there, yes?
Your former setup was a bit odd - 205F / 255R is a bit of a disparity, more than I'd want personally.
Only caveat I'll add to going 9/11 vs 8/10 is, weight. If you're sensitive to such inputs (as Ronknees was his first time, but his cavernous echo chamber renders that unpossable now)... (rotational mass sapping power and unsprung weight felt in transitional turning), and you don't "need" the footprint, err on the smaller set.
Also, rubber is cheaper in the smaller sizes (as Ronknees ohso well knows). It's going to look beefay either way, I don't think you'll have any issue there as long as you nail the ride height and offset.
BTW, the $$$ jump from 295 to 315 tires is tangible, as is again the weight penalty. I went 295 on my 11's.
You can also consider 18's heh heh...
With regard to beef, it really all boils down to this resounding phrase that will haunt Ronknees to infinity, as it is ALL he hears from ALL the particularly disappointed dudes (many, and yes - dudes) he's ahem "with":
(yeah, that's right - muuffuukkaahh!!!)
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 01-23-2015, 05:48 AM
930T Owner
Hams930T's Avatar
Hahahahaha!!!!
That is so funny..... I read your post on the way in to work this morning on my phone. I couldn't see your link, but I was planning to post this:
So funny!
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 01-23-2015, 06:27 AM
Banned
Paul, where in Will's original post did he indicate a fondness for the gangsta', or vatos locos, lifestyle?!?!?!
Chris, that picture of the "where's the beef" woman aiming her mouth at a phone is similar to pics of Paul that are in internet circulation, only Paul is not holding a telephone up to his unhinged pie-hole !!!!
Old 01-23-2015, 09:37 AM
Large Member
krasuskyp's Avatar
^ya know^, I ALMOST photoshopped a pic of such in lieu of the phone and made the same observation of you, but figured it too crass.
Great mindz!
ps. FU! (it's been entiiiiiiely too long since I've fling'd one of those yer way bizzaaatch, eh?)
past:
Old 01-23-2015, 09:49 AM
930T Owner
Hams930T's Avatar
Great mindz!
I think we've come to expect such crass from the likes of you sir
Chris
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 01-23-2015, 09:55 AM
Banned
All crASS all the time!
Thanks for the FU, Paul, and in keeping with post #3, I reciprocate a heartfelt . . .
Old 01-23-2015, 10:15 AM
