IMR-Merlin's Avatar
Looks like someone stepped off that slippery slope!!!
Old 04-27-2015, 01:47 AM
The little things
Have been working on the car some this summer. My son and I made a new gas flap. That was a fun project we could do together.
Old 09-20-2015, 04:49 PM
Alternator rebuild.
The alternator had excessive wear to the slip rings, bad regulator, and bad front bearing. I tore it down, bead blasted the case, tested the diodes, cleaned and re-coated with red electric motor varnish. Painted the housing with satin black VHT brake caliper paint, baked at 400 deg. Replaced bearings, replaced slip rings and regulator and assembled.
Old 09-20-2015, 04:59 PM
Rust engine tin needed some attention.
Rear most tin over the turbo had some rust holes. This resulted in another father son project to make a few patterns that I will cut out and butt weld in.
Old 09-20-2015, 05:05 PM
I love this thread. Keep it up!
Cheers,
Patrick
'78 930 #441
'87 951
Old 09-20-2015, 05:07 PM
Acid
The rest of the engine tin I stripped, and prepped with phosphoric acid. Painted it all with satin black VHT brake caliper paint and baked at 400 deg.
Old 09-20-2015, 05:20 PM
Boost
I took apart the turbo. Lots of burned up oil, but all the internals look good. It's boxed up ready to be re-balanced once I decide who to send it to.
Found a NOS rebuild kit that will be going in after balancing.
Old 09-20-2015, 05:33 PM
More VHT
I carefully masked off the compressor housing and bead blasted it clean. Painted it with silver VHT brake caliper paint, and baked at 400 deg.
Old 09-20-2015, 05:38 PM
Alan L's Avatar
Originally Posted by kenikh View Post
Here comes the fear...
No need to fear - as long as you have a good credit card. $s can fix anything.
I'm wondering if son is going to inherit this car when Dad gets alzheimers down the track and another project thread starts. Like 'I remember the day dad bought this car home and helped him restore it"
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 09-20-2015, 06:03 PM
wgwollet's Avatar
Great car and thread.
Just curious do you plan to leave the car paint alone or a repaint? I get mixed ideas...some say never paint it, leave as is original. Others say it has too bad of a paint job, and others try to blend the paint, leaving as much original.
I think doing mechanicals is first.
Old 09-20-2015, 06:08 PM
Hukdunfoniks's Avatar
Thumbs up
Love the son and father thread. My sons too young just yet
Old 09-20-2015, 08:38 PM
Paint
I plan on getting the car running and driving before repaint. In my opinion this paint is too far gone to consider saving. I will cross that bridge when I come to it. It may be years before I have to worry about that.
Old 09-21-2015, 03:17 PM
keitho64's Avatar
Looking good, great find and building memories with your son.
Old 09-22-2015, 02:59 PM
Splice in extra wire to the Alternator.....
Before I re-installed my alternator I spliced in extra wire to the harness so I would have an easier time getting at those small shroud nuts... BTW Nice work.
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 09-22-2015, 03:39 PM
David, Congrats on the very nice turbo find
Looking forward to seeing updates on your restoration project. Best of Luck.
Old 09-23-2015, 01:24 AM
Great find and great work!
Keep us posted as to your progress.
Subscribed.
Old 09-23-2015, 06:02 AM
Turbo Rebuild
I am trying to decide how to proceed with the turbo rebuild. I sourced a NOS KKK rebuild kit and had planned on building the turbo back myself. I am now leaning on sending the parts up to Tim at Tim's Turbos - Turbocharger Rebuilding and Sales
Anyone have a comment?
See closeup of the tag on the rebuild kit. A couple of people have asked where I got the rebuild kit. It was on ebay, not listed very well and I snatched it.
Old 09-28-2015, 03:22 PM
Your 3k rebuild kit has a 270 degree thrust bearing which is standard. Thats what comes in them from Borg Warner.
A 360 degree thrust bearing has more surface area and is more durable. It also has better oil control. Durabilt Turbo upgrades these turbos with a 360 degree thrust bearing when rebuilding them and then the assembled cartridge assembly is high speed VSR balanced.
I'm sure the place you mentioned does a good job too and maybe you can just mark the turbine wheels with a sharpie pen and reassemble it yourself in the same position it was before you took the compressor wheel off.
If you want reliability with a warranty I'd send it out. If you want to try rebuilding it yourself maybe it will work.
How does the shaft look under the blue masking tape? If it's blued from extreme heat towards the turbine wheel end it might not be perfectly straight anymore. If it's scored from coked oil and the piston ring grooves are eroded it's probably no good anymore.
Good luck with it.
Old 09-28-2015, 04:01 PM
I am getting ready to paint the fan and housing. I have been reading up on magnesium and how to prep for paint. Here is the recommended prep procedure I am following. Caustic wash parts in hot water. (ph greater than 11) I used half and half mixture of TSP and TSP PF.
Old 10-02-2015, 03:16 PM
The parts were already as clean as I could get with solvent parts washer, and washed with soap and water.
Old 10-02-2015, 03:19 PM
