Brando
quattrorunner's Avatar
genius.
Turbo powa!
1977 911s. it's cool
Old 10-13-2016, 08:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by reclino View Post
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-13-2016, 09:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
tomdeg's Avatar
So what did you use inside the tank, and how did it come out?
Awesome work, BTW.
2014 Turbo S
F430
Old 10-13-2016, 01:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
really neat to see your ingenuity.
Old 10-13-2016, 01:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
I have tried a number of different cleaning solutions. Industrial strength degreaser mixed with boiling water, TSP and boiling water. TSP-PF and boiling water, Cascade dish detergent and boiling water. I also bought 5 gallons of Evaporust and tumbled that for 24 hrs. The best cheapest solution so far was 2 cups Cascade, 1 cup TSP and 5 gal boiling water. The Cascade has sodium silicate in it as a corosion inhibitor and prevents flash rusting while tumbling. So after 5 days of cleaning the tank is looking good.
Old 10-13-2016, 07:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
It's still going right now, but I hope tomorrow I can say it's finished.
Old 10-13-2016, 07:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Brando
I'd place some stainless steel nuts and bolts of different sizes inside there as well.
Turbo powa!
Old 10-13-2016, 08:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
I thought of that as well but the sump is plastic, and likely brittle. Other people working on these tanks have broken the sump with finger pressure.
Old 10-14-2016, 01:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Engine top end refresh
So I finally tore into the engine. All 24 head studs were intact, and I got them all out without breaking anything. Now just waiting on some parts before sending the heads off. Anyone have a set of valve springs available? Eibach 20701.212 EVS valve spring set.
No broken rings and pistons seem to be in good shape.
Shown is a before and after shot of the cylinders. Its amazing how nice glass bead blasting makes aluminum look.
Old 01-17-2017, 12:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Cylinders looked crusty on the outside but nice inside. Need to measure for roundness and taper.
I had some help from my son removing the head studs.
Old 01-17-2017, 12:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
All 6 heads cleaned up well enough to send out. Exhaust valve guides are quite worn, intake guides have some wear, will be replacing them all with Colsibro (copper nickel silicon) guides from Chris Seven.
Old 01-17-2017, 12:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
You never said how much you got her for
Old 01-25-2017, 02:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
Nope
Old 01-25-2017, 04:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Fun task for tonight is gluing the corners of the intercooler gasket back together. Not as easy as I thought it would be. Intercooler is clean now, and has a fresh thin coat of VHT brake caliper paint. Baked on.
Old 01-25-2017, 04:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Your intercooler looks amazing great job
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 01-25-2017, 05:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
It was looking pretty ugly when I got the car, spent most of Sunday cleaning it, in parts washer first, then in the bathtub. About an hour with a piece of welding wire picking clearing many fins jammed up with pine needles and seeds.
Old 01-25-2017, 05:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Valve springs arrived the other day. For some reason Eibach has stopped making these springs? Lucky for me aPelican who is an employee at Eibach was able to dig up qty 13 springs for me. Got a spare for no good reason.
Old 01-25-2017, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
Special delivery from Chris Flavell at Fenn Lane Motorsports in the UK arrived today. Words can not describe.
Old 01-27-2017, 02:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
The pistons cleaned up very well. I soaked them in aircraft paint stripper and all the carbon wiped right off with very little scrubbing. Have Total Seal piston rings to go back in.
Old 01-28-2017, 07:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Oil return tubes got a coat of VHT clear brake caliper paint and then baked.
Old 01-28-2017, 07:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
