-   -   "Barn find" 1986 911 turbo (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/848849-barn-find-1986-911-turbo.html)
reclino 01-26-2015 07:19 PM
I found the car through a friend of mine at work. He mentioned that a friend of his had a Porsche that was "REALLY FAST" but it wouldn't start cause the battery was dead. And it had been sitting outside in his driveway for 9 years. He thought the guy was interested in making it go away. I asked how fast? He responded it was the fastest car he had ever been in. I asked if it was a 911 turbo. He said whats a 911. So I did a little Google work and pulled up a picture of a 911 turbo, he said yeah that's it, wrong color though. Long story short, I bought it and towed it home to share space with my two 924 turbo project cars. (Anyone want a sweet deal on a 924 turbo or two?)http://forums.pelicanparts.com/uploa...1422328621.jpg
Here it is after spraying off all the grime. The paint looks better wet.
http://forums.pelicanparts.com/uploa...1422328664.jpg
phrogs 01-26-2015 07:41 PM
nope you should sell me that turbo for a sweet deal because the way you make it sound you stole it.
If you think about selling it get a hold of me.
Did you get it to run?
IMR-Merlin 01-26-2015 07:51 PM
Looks better than my "barn find" did.
Great score, post up your build progress....
http://forums.pelicanparts.com/uploa...1422330635.jpg
reclino 01-26-2015 07:56 PM
Bad gas
So first order of business was drain the gas.http://forums.pelicanparts.com/uploa...1422330860.jpg
Seems to require a 22mm allen key. With vise grips anything can become a tool.
http://forums.pelicanparts.com/uploa...1422330945.jpg
Here is a shot of the last 2.5 gallons of 15, in the bottom of a clean white 5 gallon bucket.
Yikes.
IMR-Merlin 01-26-2015 08:06 PM
the last of the 5 gallons of 1993 race fuel were CHIPPED out of my outlet tube, you got off easy. LOL
shlobeck 01-26-2015 09:10 PM
Nice... Garnet red metallic, with factory gold wheels, and I'm assuming champagne interior. It's unfortunate it couldn't have be stored indoors all those years. Good luck, they're among the best porsches ever made..
quattrorunner 01-26-2015 09:15 PM
*****en!
B I t c h e n!
Highway-Star 01-26-2015 10:37 PM
I love barn finds!
One facet is, it has stood outside.
Another is, no one has messed with it during that time.
redturbo911 01-26-2015 11:26 PM
Now that's a sweet find.
will hung 01-27-2015 04:40 AM
Nice color combo, congratulations.
Azzurro 01-27-2015 05:31 AM
Nice find! Here is what mine looked like when I found it 2 1/2 years ago.http://forums.pelicanparts.com/uploa...1422365462.jpg
slow&rusty 01-27-2015 05:42 AM
VERY cool.
Miguel Antonett 01-27-2015 06:03 AM
Prrrrrreeeeettycool!
Welcome to the forum, and first of all "enjoy the journey".
How about some shots of the engine bay and interior...?
911SauCy 01-27-2015 06:07 AM
make it run
drive it with the crust...you'll be a movie star
great find
reclino 01-27-2015 07:16 AM
1 owner
Prior to the sale I suspected I had found a gem in the rough. The car had 68,000 miles on the clock. http://forums.pelicanparts.com/uploa...1422371627.jpg
The owner said he bought it in 1987 from the dealer in Charlotte, North Carolina. When I pulled the vehicle history report it indicated that there was only one owner, the dealer had put 7000 miles on it between 1986 and 1987. So I am now the second owner.
reclino 01-27-2015 07:58 AM
Pull Alternator
Next up is to pull the alternator.
reclino 01-27-2015 08:03 AM
http://forums.pelicanparts.com/uploa...1422374399.jpg
Took about an hour to get to this step, then about another to figure out how to get those little 3 screws and washers off the rear housing without dropping them or breaking anything.
http://forums.pelicanparts.com/uploa...1422374507.jpg
Flipped the fan housing over and carefully dropped it on the two blocks to allow the alternator to "hammer" itself out.
http://forums.pelicanparts.com/uploa...1422374607.jpg
reclino 01-27-2015 08:09 AM
Alternator rebuild
The rear bearing tolerance ring is marked Porsche, the Valeo voltage regulator has a date code of 4/90. The slip rings are worn and the owner indicated he was having charging problems when he parked the car in 2003. All the diodes test good, I will get the unit tested as it is, but have already ordered rebuild parts, brushes, slip rings, and bearings. Hopefully I can rebuild it myself. I would really like to rewire it for an oversize external regulator. I should be able to clip the leads on the existing regulator, make a harness and put a volt regulator over next to the ignition box. Has anyone ever done this?
willtel 01-27-2015 09:25 AM
Since everyone wants to know but is apparently too polite to ask...
What did you pay for it?
unclebilly 01-27-2015 10:33 AM
Does an 86 have an external regulator inside the engine bay on the driver's side?
I know some were internally regulated... These are like $25.
What a shame to see the car get to this state of repair for a simple and sub $500 repair...
Good 'on ya for seeking out the car and bringing it back. This is pretty similar to my 77 911 when I got it... neglected but had good bones and everything was repairable. In the case of my car the 'trusted mechanic' was incompetent and had the CIS so badly out of tune it would hardly run - the PO got fed up and sold it cheap.
reclino 01-27-2015 10:49 AM
It is an internally regulated alternator. The Valeo regulator is $65 the Huco runs about $30. But my past experience with Bosch voltage regulators and the location of this one being so hard to get to if and when it needs to be replaced. Why not spend the few extra bucks and put one like this external.
Voltage Regulator V1200
voitureltd 01-27-2015 12:59 PM
Good laugh, that's great.
heliolps2 01-27-2015 01:03 PM
Also check if the cables at the starter are tight , The power from battery goes the starter to the alternator and back , i replaced three alternators and regulators thinking they were the problem, I would start with a fresh Battery and make sure all connections are nice and tight , Grounds starter cables and so on,
Good luck
reclino 01-27-2015 01:36 PM
I discussed price with the owner, he had know idea the current value of the car. I gave him a few days to look up the car value, and come up with a number. He named his price, I tried to negotiate down from that number. He didn't want to budge and I paid his price. I will not be further discussing the price I paid, but I do not feel like I took advantage of him.
http://forums.pelicanparts.com/uploa...1422394256.jpg
http://forums.pelicanparts.com/uploa...1422394455.jpg
http://forums.pelicanparts.com/uploa...1422394552.jpg
IMR-Merlin 01-27-2015 01:47 PM
If he gave you a number and you paid that number. Then you didn't take advantage of him.
kenikh 01-27-2015 01:48 PM
Awesome
Miguel Antonett 01-27-2015 01:51 PM
I don't believe you can find those two separate anymore - really don't want them - alternators nowadays come with the regulator within... the way to go.
BTW, amazing how that IC rubber seal is still together at the four corners... I buy it from you, but don't take advantage of me now - kidding.
redturbo911 01-27-2015 01:58 PM
True
+1 agreed
Roby466 01-27-2015 02:20 PM
Very nice! I can't wait to see where this is going. Looks like a great car has been saved! Keep us informed of the progress.
unclebilly 01-27-2015 02:56 PM
There are some things you may or may not know about these cars... I am assuming this is your first 911 / 930.
Rule number 1. These are dry sump. Don't fill up the oil based on the dip stick level before you start it. Change the oil and put in 10 quarts and then check it warm. If you top up the sump with it cold, you will have a big mess to deal with.
Tt surgeon 01-27-2015 02:58 PM
+1, big time!
Ferraripete 01-27-2015 03:05 PM
if purchased new in charlotte, it would have been sold by Barrier & Beck Porsche. it may have been Skipper Beck's personal car. Skip passed away too young. He loved his turbos!!
reclino 01-27-2015 03:57 PM
Beck
The license plate frame says Beck-Hendrick. I am new to the 930 but not new to cars and things mechanical. I appreciate and welcome all the advice. I will be dropping the engine out next to get a good look at it. I assume that I will at least pull the heads and do an inspection of everything. I am very concerned with the condition of the head studs, if the Dilvar has not yet died from stress corrosion cracking I fear it soon will. Sitting in the humid air of Eastern North Carolina for 9 years will do some nasty things to unprotected metal. Can anyone determine if the head studs are original from the picture of topside of engine? I thought the Dilvar studs were bigger around than the steel ones, and to my eye the head studs all look intact and not corroded.
http://forums.pelicanparts.com/uploa...1422402819.jpg
unclebilly 01-27-2015 05:18 PM
Those studs look OK to me. Seriously think about pulling off the heads - this is not a simple afternoon job on these engines - if you do go down this path, get Wayne Dempsey's book on rebuilding these engines.
You can retorque the head studs with the valve covers off. Honestly, I don't know if those head studs would be worse off if they were heat cycled regularly over the past 9 years as opposed to sitting for 9 years.
I am not questioning your mechanical aptitude or experience - I thought I knew all this stuff too until I rebuilt my first 911 engine... the dilivar head studs look like the lower ones on my engine.
http://forums.pelicanparts.com/uploa...1422407848.jpg
kenikh 01-27-2015 05:30 PM
In a similar circumstance I left mine alone on the advice of my mechanic.
Ronnie's.930 01-27-2015 05:31 PM
The original dilivar head studs on your year of Turbo are painted black (on some other 911 models & years they are goldish in color), so based on your picture, I would say those are the originals.
You are probably aware of this, but if not, all of the head studs on the turbo engines are dilivar (top and bottom), and in the opinions and experience of many here and in the 911 forum, a snap just waiting to happen.
kenikh 01-27-2015 05:40 PM
Maybe he's lucky, but my mechanic said he's never had a dilavar stud let go on a 930 or 935 in 40+ years. I was going to go Supertec and he talked me out of it.
Ronnie's.930 01-27-2015 05:58 PM
^^^ Well that's a first for me, as I have never heard of an experienced mechanic suggesting to re-use, or buy new, dilivar studs (other than the 993TT, all-thread variety) - interesting.
CBRacerX 01-27-2015 06:02 PM
Great find! Replace the studs, not worth the risk and if you already have the heads off it is easy. Unless they snap being removed. If I was you, I would split the case and inspect everything, clean the crank oil passages etc then reseal as in a rebuild. Have fun.
kenikh 01-27-2015 06:03 PM
Came as a surprise to me given prevailing wisdom here. He knows his stuff. I've been with him for a decade and in that time a) he's never steered me wrong b) I've seen more 935s and 962s in that shop (amongst other equally interesting cars) than I can shake a stick at. He's been at it since '72, so it's on his side. Of course if I pop a head stud during test pulls... ��
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
