New Trunk Lid Shocks Failing
I have new trunk lid shocks on my 930 (singles on both sides) and they still won't hold up the lid I'd like to stay original but having a broom handle to hold up the trunk isn't ideal either.
What are your thoughts on the Pelican double shock? I guess I'd put these on both sides and have a total of 4? Seems like overkill but what I have now isn't working.
I'm assuming I'm not the only one with this problem. Any advice would be appreciated.
Old 02-22-2015, 02:37 PM
I had to replace mine when I got it, if I remember right deck lids with a tail used a different shock than ones without.
Old 02-22-2015, 02:48 PM
Guess not, I just looked. I used the weltmeister with no problems.
Old 02-22-2015, 02:57 PM
AskewRSR's Avatar
Look for Mechanical hood shocks There is a guy making them.
1967 911 S Bahama Yellow
1969 911 Golden Green 2.0 Twin Plug
1971 911 S Gold Metallic. Peter Gregg
1974 911 RS Euro Metallic Blue Gold lettering
1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor
Old 02-22-2015, 03:26 PM
I installed a couple of the extra heavy duty hood struts Pelican sells in 2006 and they still hold the front hood up really well.
Another nice solution made of carbon fiber with a small aluminum rod end is the SEINE SYSTEMS Ultimate Strut.
Seine Systems > Ultimate Strut
Old 02-22-2015, 07:35 PM
Banned
Pharris, I've got two (one on each side) of the Meyle branded struts on the tail that I ordered from Pelican - no problem from them for the past two years or so. Maybe you got a couple that were lame ducks?
Edit - I have the same ones on the front (hood/frunk/front trunk) and they have been problem free, too.
Old 02-22-2015, 08:08 PM
Driver
Noah930's Avatar
Wait. I think some people are talking about the frunk and others about the engine lid.
Old 02-22-2015, 08:19 PM
Old car guy.....
Hot Euro's Avatar
[QUOTE=Pharris409;8499662]I have new trunk lid shocks on my 930 (singles on both sides) and they still won't hold up the lid I'd like to stay original but having a broom handle to hold up the trunk isn't ideal either.
When I first purchased my car I installed all new frunk and engine lid struts from a lesser known source. These didn't last long (one actually broke the end off) so I got a set from our host. These are much heavier and have lasted the first year with no problems. One on each side front and a twin pair left rear. You get what you pay for.
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 02-23-2015, 03:44 AM
Metal Guru
911nut's Avatar
It would be tough to use any mechanical solution on the engine lid. If you did, someone would have to grab the lid when you pulled the release, unless you have arms like a great ape The gas shocks will pop the lid off the latch so you can walk around and lift.
I replaced all my shocks from stuff in Pelicans's stock (I think it was the heavy-duty shock) 6 years ago and they are still working well.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 02-23-2015, 04:07 AM
They all fail..., it is a matter of time to replace them or the "broom stick" method. If you go double duty it might mis-align the panel. Just change them, piece of cake! BTW, front and rear are different; and the heavy duty ones last a little longer - sometimes...
Old 02-23-2015, 10:21 AM
Mine "failed" last winter during an engine drop and it was low on the list to fix at the time. Then last spring came and they were perfect, worked great all summer. I lift the tail after every ride to cool off the turbo and it stays up until I shut it. Then I store the car all winter anyway.
I just figured the operating temperature favors warmer weather and a new pair probably would not change it that much. Sounds true based on all the other comments I read. Early Cayenne's had a similar issue - maybe designed for milder German winters.
Old 02-23-2015, 11:35 AM
Great info, thanks. I just ordered a set of heavy duty rear deck lid shocks from Pelican. Sounds like they should do the trick for a couple years.
Old 02-24-2015, 08:03 PM
