Opinions on my AFR curve?
I pulled the car out of storage today and did some data logging, and would like some expert opinions on my AFR curve. As background, my car is nominally a stock '87, with a fabspeed muffler and andial intercooler. Last year I replaced the injectors and the rear pump with stock pieces from our host. The lambda system is still in place, although I have the O2 sensor disconnected.
From what I've read here, a stock car should be dropping to low 10's or even high 9's at peak boost, and lean out to low 11's or so at max RPM. I'm in the low-mid 11's at torque peak. Should I be worried about this?
Backing HP and torque out of the accelerometer data from my LM3, and assuming 15% drivetrain loss, I'm seeing the following curves. Seems in the right ballpark to me with these simple mods.
Old 03-08-2015, 09:09 PM
dos531's Avatar
You dont want to be in the 9s or 10s at any point. Your number look great for a stock car.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
'01 996tt
Ducati 748R
Old 03-08-2015, 09:20 PM
Chain fence eating turbo
Ditto.
From my experience, 9's yield severe loss of power and misfires.
Old 03-08-2015, 09:43 PM
Turbofrog
smurfbus's Avatar
If that is accurate (WB) data then you have extremely good tune!
79 930: HX40Super, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, BB+2*turbosmart38, WMI. Weight 1110kg
Old 03-08-2015, 10:37 PM
Looks great to me, I would leave it....
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 03-09-2015, 10:25 AM
Thanks guys. That makes one less project for this spring. Moving on to tearing out my noisy ER polybronze bushings in the spring plates and refreshing the brakes.
Old 03-09-2015, 04:29 PM
