-   -   Is specific fw needed with starter ring adapter? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/860164-specific-fw-needed-starter-ring-adapter.html)
smurfbus 04-11-2015 11:53 AM
I think I have a worn out fidanza fw and now I have found out that it needs a riveted friction plate if I can find a place where it can be done. Or I can send it to fidanza to have it replaced for a new one.
But there are even lighter ones available at around 500 eur but I need know if my adapter for starter ring will work for any 79 930 made flywheel. They all should have a starter ring but if its hot pressed mine will not work. This is what I have. Adapter is bolted with 9 bolts
http://forums.pelicanparts.com/uploa...1428778206.jpg
http://forums.pelicanparts.com/uploa...1428778228.jpg
proffighter 04-13-2015 05:01 AM
Maybe I don't get your question right, but what has the starter ring to do with the FW? Ring will be mounted on pressure plate, adapter or not...
smurfbus 04-13-2015 06:10 AM
In this case the starter ring is bolted to the flywheel with the adapter like in the first pic. The fw has a lip and bolt holes and I'm not sure if thats the case with other LWFWs.
